floating point numbers
Results 1 to 11 of 11
    Aug 2007
    Default floating point numbers
    i need to get a floating point numbers for a speed measurement to ensure accuarcy. Currently i have metres/hundreth which needs to be converted into mph. therefore i need a float number which pbp cant handle. any ideas would be greatfully appreciated.
    no you NEVER EVER need ANY float, and YOU DON'T want to use ANY float anyway.
    I already heard..."huh using float.. what's the point?" and i really laugh... "point" in french is dot... so translate it the way you want, you should understand what i mean Simple multiplication by 100, 100 or 10000 will solve most see all problem.. the dot is just visual effect you can override it easy using DEG, DIG and whatever else if you really need to DISPLAY it
    Float point routine are just slow and code hungry for nothing... forget about it.
    <hr>
    http://en.wikipedia.org/wiki/Floating_point
    http://www.cs.princeton.edu/introcs/91float/
    <hr>
    What's your actual value range you need to change to mph?
    Which version of PBP do you have?
    Talking
    Hi, Steve
    NO FP needed ...
    1 Mile = 1619/1006 Km w. Zero error
    1 Mile = 758 / 471 Km w. 1.35 ppm error
    1 Mile = 103 / 64 Km w. 19.3 ppm error
    my favourite :
    Km = Mile */ 412
    Best of ALL
    RTFM , last edition, $ 4.17.1 p.35 ...
    " if you wish to convert miles to kilometers ... etc,etc ..."
    PS: What about THAT ???
    http://www.miscel.dk/MiscEl/miscelIntegerMath.html
    http://www.miscel.dk/MiscEl/miscel.html
    Just to be downloaded ... no ???
    Aug 2007
    for example if i want to do a calculation 80/2.74 = 29.1971
    how would i go about doing this to get the 29.1971 value. i could times up the 80 by 100 but i cant go above 65535 since that is the size of a word. Any ideas on how to get the value of 29.197 so i can times it by a conversion rate?
    Aug 2007
    if i do
    x = 2560/153
    x should = 16.73..... but pbp will see it as 16. therefore i wanted to use the remainder function to get the 0.7
    remainder = 2560 // 153
    but when i print it out on an lcd it says that the remainder is 0. Why is 7 not stored ?
    I see some several ways... which PBP version, which PIC?
    Aug 2007
    its a pic16f77
    pbp version 2.3.0.0 and
    mplab ide v7.60
    many thanks
    Talking
    V2.30 with 16F77 ...
    might provide interesting moments ...
    PBP 2.50a upgrade....only $25....
    How much says the O/P can't get it?
    Well Alain is right this device is not supported in this version... pretty old one i have to say
    Really worth to upgrade everything you have on hand.
    MPLAB is free and now V8.xx
    PBP: now V2.50
    Bombay, India
    Thank you very much for pointing to this very useful utility.
    Jerson
  1. Getting out of floating point
    By jcb344 in forum General
    Last Post: - 5th August 2008, 22:18
  2. Floating Point Display Problem (serial string out)
    By Cash Olsen in forum mel PIC BASIC Pro
    Last Post: - 20th December 2007, 03:03
  3. ADCin and floating point values
    By niknaksbarbeque in forum mel PIC BASIC Pro
    Last Post: - 19th May 2005, 12:38
  4. Floating Point
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 15th May 2005, 15:19
  5. DIV32 instead of floating point routines?
    By Tomasm in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2004, 08:50
