Decoding an incoming infrared signal: need advice
Results 1 to 11 of 11
    Maybe you can find some tips with the following
    http://rentron.com/PicBasic/IR_Chips.htm
    From the bit timing you indicate, I would guess this is a Sony IR transmitter? PULSIN should
    be all you need to decode this type. It's one of the easiest around to encode & decode.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    xnihilo's Avatar
    xnihilo Guest
    Smile Decoding routine for IR encoded signal
    No guys,
    I can't change my hardware.
    BRUCE:
    "From the bit timing you indicate, I would guess this is a Sony IR transmitter? PULSIN should
    be all you need to decode this type. It's one of the easiest around to encode & decode."
    It is a VISHAY TSOP4840 receiver (see mouser for the datasheet) and the emiter is a VISHAY TSAL6100 led. I'm using pic's PWM output to encode and I need to decode on the other side but do it quickly and acurately. I'm not using pulsin, I'm polling the input pin, what's wrong with that?
    Nothing's wrong with polling, if it works for you. I just prefer PULSIN since it's more
    than accurate enough, and a lot easier.
    -Bruce
    tech at rentron.com
    xnihilo's Avatar
    xnihilo Guest
    Smile
    I agree.
    Thank you very much.
    xnihilo's Avatar
    xnihilo Guest
    Smile
    I have a strange behavior.
    The signal I am supposed to get is:
    Assuming the normal state is low, I drive the input pin low with an IR receiver-demodulator.
    2400us low (=header), then for each of 16 bits I have a bit prefix which is a 600us pause then if the bit is = 1 there will be a 1200us low or if bit = 0, there will be 600us low.
    The incoming IR signal triggers an int on RA4 and then I start pulsin-ing to get the data.
    The sequence I get is something like:
    127,261,136,251,140,137,137,136,136,247,261,136,24 7,0,0,0
    0,1,0,1,0,0,0,0,0,1,1,0,1,?,?,?
    There seems to be an offset somewhere. I don't seem to get the first bit.
    Maybe it takes too much time to get to the routine that checks the pulse durations???
    The data structure I am supposed to get is:
    0,0,1,0,1,0,0,0,0,0,1,1,0,1,?,?
    Here is my code, in the case someone has an idea:
    '----- HEADER PULSE ------------------------------------------------------------
    'based on pulsin routines from: http://rentron.com/PicBasic/IR_Chips.htm
    PULSIN PORTA.4,0,pulse_in        '// Read-in start pulse - in a word var!!
    IF (pulse_in < 480) OR (pulse_in = 0) THEN '// Less than header, then keep looking
       'GOTO bypass
    '----- get 2 databytes ---------------------------------------------------------
    'Maybe it is too late to get the header because pulsin may reacto to a high to low transition
    'while we are ALREADY in the low state, so the header will be bypassed ????
    FOR i = 0 to 15                     'get a sequence of incoming 16 bits (WITHOUT their prefixes)
        PULSIN PORTA.4,0,ir_pulse[i]    '// Read 16 low-going pulses on RA.4
    NEXT i                              '// Loop 16 times
    '    LCDOUT $fe,1,"hdr:",#pulse_in
    ' PAUSE 2000
    'databyte = $FF                    '// Start with all 1's and find each 0
    'we scan the second byte we stored from MSB to LSB
    'FOR i = 8 TO 15                     '// Get 8 "data" bits
    FOR i = 0 TO 15                     '// Get 8 "data" bits
        LCDOUT $fe,1,#i,":",#ir_pulse[i]
        PAUSE 2000
        IF (ir_pulse[i] < 240) THEN       '240*5us resolution at 8MHz = 1200 us
            databyte.0(15-i) = 0               'clear the bit
            databyte.0(15-i) = 1
    NEXT i
    xnihilo's Avatar
    xnihilo Guest
    Smile Solved
    I solved the problem.
    The header triggers the int and cannot be detected by pulsin that detects an edge.
    When int is triggered, I just check with a loop and 15us increments the duration of the triggering signal (the 2400us signal) then I use pulsin to get the bits and their length (thus their state).
    Cool.
  1. Recording incoming logic signal duration, both edges - how to?
    Last Post: - 6th January 2010, 08:56
  2. signal decoding
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 14th September 2008, 21:58
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  5. "momentary" IR decoding
    By sporker in forum mel PIC BASIC Pro
    Last Post: - 20th June 2005, 02:53
