Help with DS1821 1-wire Thermometer
Results 1 to 10 of 10
    sanpic's Avatar
    sanpic Guest
    Question Help with DS1821 1-wire Thermometer
    Hi to all.
    I need a source code to read negative and positive temperature values using a DS1821.
    I 'm using a 16f877A pic uC.
    Thanks.
    Please help me.
    here's one for DS1820... might be useful to start
    http://www.picbasic.co.uk/support/Te...b1fd954c62ca8d
    jojokatada's Avatar
    jojokatada Guest
    take a look at this code
    jojokatada's Avatar
    jojokatada Guest
    this code i am is using for pic16f84a but it can be easily modify for any 14 core pic
    sanpic's Avatar
    sanpic Guest
    Talking
    Thank friends.
    Default speed
    any help on using the temp program with a 20 osc setting
    timeing seems to be a issue
    Nov 2008
    I need a picbasic code to read DS1821. NOT for DS1820. Help!
    North Norfolk UK
    Quote Originally Posted by zdravko View Post
    maybe the Help you need is at hand with the DS18S20
    ___
    Nov 2008
    I don't have DS18S20. What's the difference between DS1820 and DS1821 ?
    North Norfolk UK
    If you are not able to buy one locally you could ask them to send you a sample.
    www.maxim-ic.com/quick_view2.cfm/qv_pk/2815
    there are a few differrences it depends which one is significant to you, maybe take a look on the same site, you could contact them as well if you wish.
    _______
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
