MPASM error message
Results 1 to 7 of 7
    Sep 2005
    Campbell, CA
    Default MPASM error message
    When compiling, I'm getting the MPASM error message
    Error [110] pbppic18.lib 832:unmatched
    I can't see any errors in the ASM files or the .MAC files. Can someone tell me how I can track down the error to a particular line of PBP?
    Charles Linquist
    Is this a complex program? Is this PBPL or PBP? Which PIC?
    MPASM help file says...
    110 Unmatched )
    An close parenthesis did not have a matching open parenthesis. For example,
    DATA 1+2).
    Maybe somewhere in your code or in a Specific PBP(L) macro.
    Sep 2005
    Campbell, CA
    PBP 2.47 (no PBPL)
    18F8720
    Long and complex program
    It would take me many hours to comment out sections to see which one was the offender.
    Charles Linquist
    If you select another PIC.. say 18F8722.. is the problem always there? if so... maybe a faulty lib... may worth to try a fresh PBP installation.
    Never ever had this message here
    Sep 2005
    Campbell, CA
    It seems that I'll never have to find out what the problem was. It compiles and assembles "clean" in PBP 2.50a.
    Charles Linquist
    ERROR: ERROR: Wrong answer! I can't count.
    Nevermind!
    Sep 2005
    Campbell, CA
    The code runs as expected. I would like to find the problem, though. Things like that usually come back to bite me eventually. I suspect that I'm equating a bit variable with a byte
    That is the trouble with the bigger chips - there are so many places for bad code to hide!
    Charles Linquist
  1. 16F914 and MPASM
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 7th February 2009, 04:21
  2. 12F675 MCLR directive MPASM
    By OLDSCHOOL in forum mel PIC BASIC Pro
    Last Post: - 4th May 2008, 02:29
  3. MPASM 18F4550 getting started
    Last Post: - 5th September 2007, 00:59
  4. 18F8722 and MPASM confusion!
    By Jackson in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2006, 02:24
  5. Converting to MPASM
    Last Post: - 4th November 2005, 02:35
