Dme
Results 1 to 9 of 9
Thread: Dme
    Dec 2003
    Wichita KS
    Default Dme
    Does anyone know where i can get a cheap DME that can go from 0 to about 120 feet? I need it to measure distance between vehicles.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    SWITZERLAND (french speaking)
    Default Measure distance with LASER diode - how to?
    Hello,
    Unfortunately, I can't find any information about what is the best way to measure distances from 1 to 10 meters. Like Dwayne, I'd like to measure distances between vehicles.
    I assume the use of a LASER diode is the way to go.
    There is no need for high accuracy; plus/minus 10 centimeter is acceptable.
    I was thinking about generate a laser pulse and, in the same time, have another element "looking" at the spot and mesuring the time between the "laser switch-on" and "I can see the spot".
    How is it realised in those meters one can find in the stores?
    Roger
    Talking Swiss speed ???
    Hi, flotul
    Question 1)
    How much is speed of light ???
    Question 2)
    Let's suppose 30 meters from the target: how many time will it take for the beam to make twice the distance ???
    Question 3)
    Is it compatible with PICBasic Pro time measurements ???
    Question 4)
    Is it compatible with PIC 32 Bits ( @ 80 Mhz ) capture units ...
    Too bad !!!
    PS for Dwayne : Cheap and Laser do not match ... till the day !!!
    Default Cheap DME are ultrasound based
    The low cost DME I have found in hardware stores have a laser as a pointing guide but do the actual distance measurement with ultrasonic sensors.
    Expensive systems, like Dimetix, Rockwell and others are true laser DME but are hundreds of times the hardware store price.
    HTH
    Brian
    Default let's find ultrasonic sensors (DMEs?)
    Thanks BrianT,
    It didn't know that these devices wouldn't use the laser to do the measurement.
    Let's find the ultrasonic sensors then...
    Roger
    Default ultrasonic sensors - where to find
    Hello,
    I'm looking now for ultrasonic distance sensors. Speed of Sound is far more in a PIC's capacity range than "Light Speed" ( Alain).
    My search by DIGIKEY, DISTRELEC, FARNELL, REICHELT, CONRAD and lots of suppliers one can find in the internet, but I'm unsuccessfull.
    I found ultrasonic sensors for distances up to 37ft (11 meters) which is almost okay but their price is high (> $500.-!!!).
    Does anyone have a suggestion where I could find those elements?
    Is there another "electronic" way to measure 1 to 10 meters distances?
    Roger
    Default A web search will yield plenty
    Mar 2008
    Texas, USA
    For giggles and grins...
    Light travels at about 1 foot per nano second.
    Kick a PIC at say 50mhz (skimask says it's "ok")
    Tcy is 1/4 clocking speed or 12.5 mips or 80 nano seconds.
    One Tcy = 80 feet or 40 feet out and back round trip, so 40 feet would be the step resolution using time counting.
    Now, clock that PIC at 4 Gigs and you can be down to 1 foot resolutions (just before that billionth of second when the PIC releases its magic smoke).
    At 50mhz, it could be interesting to see just how high that airplane is flying (NOT!), give or take 40 feet. Kids, don't try this at home. We are professionals.
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
    Default let's try à "SensComp 6500" ranging module
    Thanks BrianT,
    Your link is great, especially that one:http://www.acroname.com/robotics/parts/R11-6500.html.
    As almost always, particular modules and parts exist but finding the correct wording for a good web search is sometimes the most difficult thing to do - Ranging Module was the key.
    I already ordered one part - getting ready to play with it
    Roger
