I'm using the K8084 development board to learn how to use picbasic. The board uses the 16F627 chip with the LED's on port b and buttons on porta. The input from a button is high when pressed.
The following is the code I'm using to try and get the buttons working, but it doesn't work.
B6 var byte
button1 con 1
TRISA = 0
loop:
B6 = 0
button button1, 1, 10, 5, B6, 1, pressed
goto loop
pressed:
TRISB = 0 ' PORTB is output
PORTB = %11111111 ' Turn ON diodes on PORTB
PAUSE 1000 ' Wait for 1 second
PORTB = $00000000 ' Turn OFF diodes on PORTB
goto loop
Can anyone see what is wrong.
