What kind of temperatures affect them? Are we talking 1 or 2 degrees could alter it or like 20-30 degrees? Most of my stuff would remain at more or less the same kind of temperature give or take a few degrees.
PIC16F84 don't do much and absolutely need an external crystal+MCLR connection.. 16F628 have comparator, MSSP, USART, no real must for external MCLR (this gives 1 i/o for free), can use it's own internal osc (that's 2 more i/o for free) and so on. More with PIC16F88, and a bit more with 18F1320. and there's still the codespace...
There's some temperature curves in the datasheet you can refer to. I still repeat, unless you need a real timing accuracy (e.g. high speed asynch serial comm), internal osc may be just fine. 16F88 one can run up to 8MHz, 18F1320 up to 32MHz!
This is the quick way to start picking PICs.
http://www.microchip.com/ParamChartS...g=en&pageId=74
http://www.microchip.com/stellent/id...PAGE&nodeId=74
And I do read many many data sheets. Not that it helps muchAlways fall asleep.
Ive seen that site before but i had trouble using it. It looks like all the information is there but searching and displaying it could be improved a bit.
In the second link (and the dropdown on the first). Should i always pick PIC16MCU? I dont get that bit and there doesnt seem to be any description of whats different between them
The 16MCU will take you to the 16C/16F chips. 18MCU will take you to the 18C/18F chips etc.
