Pulsin Math question
Results 1 to 10 of 10
    Wink
    Quote Originally Posted by ruijc View Post
    Thanks for the tip Acetronics
    What do you sugest ? What will it work better ( for a Futaba RX ) ?
    1) I always use 25ms for PULSIN_MAX ...( add the pulse duration and it's Ok for all ! )
    2) Ah, Futaba RXs !!!
    Some care has to be taken for Futaba and Sanwa, some of their receivers output a ~ 3.5v high level ...
    So, They will work with a TTL input, but not with a Schmitt trigger input ( as PortB.0 in interrupt mode i.e ...) : it will work with a PULSIN PORTB.0 , but not ON INTERRUPT (i.e.) ... that can offer happy debugging times !!!
    Thanks Mister-e
    Thanks Acetronics
    To protect the hardware i was thinking of placing a 220 Ohms resistor between the RX and the Pic.
    Hope it works
    From the Rx outputs , one might consider not to draw more than 1 mA in all circumstances ... so, 4.7k in series, and 100k for an input Pulldown are safe values. 47k in series do not introduce significant noise levels ( 470k then for Pulldown !!! )
    Thanks for the tip Acetronics,
    OK...( let's see if i understood ) will use the 4K7 between RX and Pic and the 100K pulldown for the pic's input pin.
  1. Math question
    By vios in forum mel PIC BASIC Pro
    Last Post: - 22nd September 2007, 19:53
  2. Question for a math guru
    Last Post: - 22nd November 2006, 09:45
  3. pulsin question
    By schu4647 in forum mel PIC BASIC Pro
    Last Post: - 29th May 2006, 20:46
  4. PulsIn question.
    By Peter Oors in forum mel PIC BASIC Pro
    Last Post: - 15th January 2006, 22:03
  5. Math question...
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 15th June 2004, 22:03
