Hi All
Ioannis:
I have dabbled in building manufacturing CNC machines, the word that stands out is precision / repeatability , and for that you need to spend proper money. I know you are using precision in the subjective sense, but just look over at the hosted sister forum (no nameI am looking for parts that would give the precision for the job.) and look at the problems that even a simple CNC can generate like the recent debacle over a “hobby” colinbus kit.
We know there is a plethora of sites dedicated to CNC but I have found that www.cnczone.com and its extensive forum always always worth a visit. In the UK automotion has been making a presence over the last few years at the big manufacturing exhibitions. They have a some reference books particularly “linear and rotary motion components” which is a handy start, they are at www.automotion.co.uk
Of course Wixroyd has to be listed for accessories.
In any event one main enemy is going to be vibration, the foundations of a plant in my opinion is of singular importance, you can spend hours farting around tweaking with dampers, braces etc, but there is nothing to beat a good solid ground flat base and if you can’t bolt it to a concrete floor then secure it to a pile of concrete slabs.
As for fascias, I sometimes use Quick-Mark which is the replacement for the 3M Dynamark, but if you are only wanting one-off prototypes, there is nothing to beat a photocolour inkjet print and a simple laminating machine. Use a laser or sublimation inks for UV stable prints, I havn’t tried it with a wax printer yet. Fix them with a permanent photomount spray, if you do suffer from possibility of curl then use carpet fixing spray adhesive. Sometimes I use my PCB layout software (Eagle) as the Artwork source, creating separate colourways in unused layers, very useful when rearranging components that project or are position critical through the enclosure/artwork.
Duncan
