problem with sending data using RF module
Results 1 to 40 of 52
Threaded View
  1. #38
    Mar 2008
    Unhappy
    Shouldn't be that critical for few millivolts. Are your Encoder/decoders address pins tied to ground as in the document i sent?
    Yes.All the Address pin for both encoder/decoder was tied low. I also connect the TE pin to GND for HT12E,but still no data receive at Rx. I'm not assuming that both encoder/decoder is damage because I have extra pair for HT12E and HT12D. when I use it, the result is same with the previous pair I have.the Holtek's data sheet say that the VT pin at HT12D will goes high to indicate valid transmission but my VT pin always LOW.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
