I use absolutely the same value of resistor in the PDF but the encoder/decoder still not function with direct connection.I can assure that Both Ground,Dout and Din pin was connected in the right position after chek it a few times. I'm curious about "transmitterPin Var portA.0"..
Do I need to put it in my program if use HT12E and HT12D ?
