problem with sending data using RF module
Results 1 to 40 of 52
    Hi Steve,
    Most Holtek encder/decoder ICs have internal pull-ups, so floating these pins is the same
    as connecting them to Vcc. This should be in the data sheet. The 8-bit series are tri-state.
    But I never allow them to float. Especially in an application with an oscillator or embedded
    controller that's going to indroduce a ton of digital switching noise to the power supply rails.
    I've only seen maybe 1 in 10K failures with a set of Holtek encoder/decoder ICs. 9 times out
    of 10 it's something simple like noise, a single bit difference in the address, bad connection,
    wrong oscillator resistor value (voltage dependant), or just plain wired wrong that's the
    cause of failure.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    As you know, i'm not a "left unused pin floating" fan. Was just for my own curiosity.. yeah datasheet says it could be left unconnected but.. erm...
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
