Try those with direct connection.
Notice the change in the Keypad scanning routine... this one seems to never have any erratic results now.Code:' ' TX code ' ======= ' @ device HS_OSC, LVP_OFF define OSC 20 DEFINE LCD_DREG PORTC 'LCD data port DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4 DEFINE LCD_RSREG PORTB 'LCD register select port DEFINE LCD_RSBIT 7 'LCD register select bit DEFINE LCD_EREG PORTB 'LCD enable port DEFINE LCD_EBIT 5 'LCD enable bit DEFINE LCD_RWREG PORTB 'LCD read/write port DEFINE LCD_RWBIT 6 'LCD read/write bit DEFINE LCD_BITS 8 'LCD bus size 4 or 8 DEFINE LCD_LINES 2 'Number lines on LCD DEFINE LCD_COMMANDUS 2000 'Command delay time in us DEFINE LCD_DATAUS 50 'Data delay time in us TransmitterPIN VAR PORTA.0 DEFINE CHAR_PACING 500 TRISA = 0 'Set port A as output TRISB = 0 'Set port B as output TRISC = 0 'Set port C as output TRISD = 0 'Set port D as output ' Define program variables INCLUDE "modedefs.bas" col var byte ' Keypad column row var byte ' Keypad row key var byte ' Key value Synk VAR BYTE Synk = $55 ADCON1 = 7 ' Make PORTA and PORTE digital low PORTB.6 'Set the R/W bit to low High TransmitterPin Pause 500 ' Wait for LCD to start Lcdout $fe, 1, "Key In Bus ID" ' Display sign on message loop: Gosub getkey ' Get a key from the keypad Lcdout $FE, $C0, "BUS",DEC2 key ' Display ASCII key number SEROUT TransmitterPIN,T2400,[Synk,Synk,"~",KEY] Goto loop ' Do it forever ' Subroutine to get a key from keypad getkey: PORTD = 0 ' All output pins low TRISD = $f0 ' Bottom 4 pins out, top 4 pins in WHILE PORTD != $F0 : wEND ' Wait 'till all key=up PAUSE 50 ' Debounce ScanKeypad: For col = 0 to 3 ' TRISD=~(DCD COL) ' Set one I/O to output PAUSEUS 5 ' wait a little bit to avoid ' erratic results ' ROW=ncd((~(PORTD>>4)) & $f) ' read row ' IF ROW THEN ' Any key pressed? key = ((row-1)*4)+ col+1' --- YES convert key value return ' and getout of here ENDIF ' NEXT ' Goto ScanKeypad ' No keys down, go look again
Side note...There's no major advantage to use LCD in 8 bit mode.. R/W pin could also be tied directly to ground. This done you save 5 I/Os.Code:' ' RX code ' ======= ' @ device HS_OSC, LVP_OFF define OSC 20 DEFINE LCD_DREG PORTC 'LCD data port DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4 DEFINE LCD_RSREG PORTB 'LCD register select port DEFINE LCD_RSBIT 7 'LCD register select bit DEFINE LCD_EREG PORTB 'LCD enable port DEFINE LCD_EBIT 5 'LCD enable bit DEFINE LCD_RWREG PORTB 'LCD read/write port DEFINE LCD_RWBIT 6 'LCD read/write bit DEFINE LCD_BITS 8 'LCD bus size 4 or 8 DEFINE LCD_LINES 2 'Number lines on LCD DEFINE LCD_COMMANDUS 2000 'Command delay time in us DEFINE LCD_DATAUS 50 'Data delay time in us TRISA = 1 ' PORTA.0 input, other as output TRISB = 0 ' Set port B as output TRISC = 0 ' Set port C as output TRISD = 0 ' Set port D as output ReciverPIN VAR PORTA.0 ADCON1 = 7 ' Alla digitala INCLUDE "modedefs.bas" YourByteVar var byte low PORTB.6 'Set the R/W bit to low pause 500 'wait until the LCD initializes LCDOUT $FE,1, " Receiving Bus ID" Main: SERIN ReciverPIN,T2400,["~"],YourByteVar Lcdout $FE,$C0,"BUS", DEC2 YourByteVar GOTO Main
