problem with sending data using RF module
Results 1 to 40 of 52
    Dec 2005
    Furthermore, if you look at the block diagram in the datasheet from the HiMark RX3310A chip, you will see the comparator in the output circuit. Adding another will not help.
    Wow that really is some sloppy output stage. Try sending a continuous data stream of an
    equal number of 1's & 0's like 55h with a 1mS pause between each byte of data, and capture
    a scope shot of this.
    I'm curious is this data-slicer is ever squaring anything.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2008
    Hello Guys..Thanks for all the advice
    Now my Rx module works fine in a short distance around 5-6 feet.I just add 10k pull up resistor at Rx data pin and 10uF at Vcc.But If I move more than 6 feets, my Rx module start receiving noise and my LCD will display wrong counting numbers.But It's fine to me.At least it's work.I think maybe the problem is from the antenna.I just use a small wire with length 10cm each for my Tx an Rx.So anyone here have any ideas about the antenna??
    Now I'm moving foward to send a data from my keypad. IF I pressed pad1,pad2 and so on..my LCD at transmitter board will display BUS01,BUS02....What I want to do is send the word "BUSxx" each time I pressed the keypad and display it on my LCD at receiver board. So with help and some advice from mister_e..I wrote the code below.But It's not work even I Connect the transmitter and receiver pin directly.
    The FAct Is..I'm very poor with the coding..please help me guys..
    Tx part
    @ device HS_OSC, LVP_OFF
    define OSC 20
    DEFINE LCD_DREG PORTC 'LCD data port
    DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTB 'LCD register select port
    DEFINE LCD_RSBIT 7 'LCD register select bit
    DEFINE LCD_EREG PORTB 'LCD enable port
    DEFINE LCD_EBIT 5 'LCD enable bit
    DEFINE LCD_RWREG PORTB 'LCD read/write port
    DEFINE LCD_RWBIT 6 'LCD read/write bit
    DEFINE LCD_BITS 8 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 'Command delay time in us
    DEFINE LCD_DATAUS 50 'Data delay time in us
    TRISC = %00000000 'Set port B as output
    TRISB = %00000000 'Set port D as output
    low PORTB.6 'Set the R/W bit to low
    pause 1000 'wait until the LCD initializes
    ' Define program variables
    col var byte ' Keypad column
    row var byte ' Keypad row
    key var byte ' Key value
    TransmitterPIN VAR PORTA.0
    YourByteVar var byte
    INCLUDE "modedefs.bas"
    Synk VAR BYTE
    Synk = $55
    DEFINE CHAR_PACING 500
    ADCON1 = 7 ' Make PORTA and PORTE digital
    Pause 100 ' Wait for LCD to start
    Lcdout $fe, 1, "Key In Bus ID" ' Display sign on message
    loop:
    Gosub getkey ' Get a key from the keypad
    Lcdout $FE, $C0, "BUS",DEC2 key ' Display ASCII key number
    PAUSE 200
    Goto loop ' Do it forever
    ' Subroutine to get a key from keypad
    getkey:
    Pause 50 ' Debounce
    getkeyu:
    ' Wait for all keys up
    PORTD = 0 ' All output pins low
    TRISD = $f0 ' Bottom 4 pins out, top 4 pins in
    If ((PORTD >> 4) != $f) Then getkeyu ' If any keys down, loop
    Pause 50 ' Debounce
    getkeyp:
    ' Wait for keypress
    For col = 0 to 3 ' 4 columns in keypad
    TRISD = (dcd col) ^ $ff ' Set one column pin to output
    row = PORTD >> 4 ' Read row
    If row != $f Then gotkey ' If any keydown, exit
    Next col
    Goto getkeyp ' No keys down, go look again
    gotkey: ' Change row and column to key number 1 - 16
    key = (col * 4) + (ncd (row ^ $f))
    Return ' Subroutine over
    High TransmitterPin
    pause 200
    SEROUT TransmitterPIN,T2400,[Synk,Synk,"~",YourByteVar]
    GOTO Main
    Rx part
    define OSC 20
    ReciverPIN VAR PORTA.0
    ADCON1 = 7 ' Alla digitala
    LCDOUT $FE,1, " Receiving Bus ID"
    SERIN ReciverPIN,T2400,["~"],YourByteVar
    GOSUB LCD
    GOTO Main
    LCD:
    LCDOUT $FE,1
    Lcdout $FE,$C0,"BUS",DEC2 YourByteVar
    PAUSE 500
    Try those with direct connection.
            '       TX code
            define OSC 20
            TRISA = 0 'Set port A as output
            TRISB = 0 'Set port B as output
            TRISC = 0 'Set port C as output
            TRISD = 0 'Set port D as output
            Synk    VAR BYTE
                    Synk = $55
            High TransmitterPin
            Pause 500 ' Wait for LCD to start
    loop:
            SEROUT TransmitterPIN,T2400,[Synk,Synk,"~",KEY]
    getkey:
            WHILE PORTD != $F0 : wEND   ' Wait 'till all key=up
            PAUSE 50                    ' Debounce
    ScanKeypad:
            For col = 0 to 3                '
                TRISD=~(DCD COL)            ' Set one I/O to output
                PAUSEUS 5                   ' wait a little bit to avoid
                                            '   erratic results
                ROW=ncd((~(PORTD>>4)) & $f) ' read row
                IF ROW THEN                 ' Any key pressed?
                    key = ((row-1)*4)+ col+1' --- YES convert key value
                    return                  '     and getout of here
                    ENDIF                   '
                NEXT                        '
            Goto ScanKeypad                 ' No keys down, go look again
    Notice the change in the Keypad scanning routine... this one seems to never have any erratic results now.
            '       RX code
            define OSC 20
            TRISA = 1 ' PORTA.0 input, other as output
            TRISB = 0 ' Set port B as output
            TRISC = 0 ' Set port C as output
            TRISD = 0 ' Set port D as output
            pause 500 'wait until the LCD initializes
            Lcdout $FE,$C0,"BUS", DEC2 YourByteVar
            GOTO Main
    Side note...There's no major advantage to use LCD in 8 bit mode.. R/W pin could also be tied directly to ground. This done you save 5 I/Os.
    Quote Originally Posted by rano_zen06 View Post
    To start learning about antennas, go here
    http://www.linxtechnologies.com/Supp...ication-Notes/
    and read app notes AN-00500 and AN-00501.
    Let us know if you need anything clarified.
    Forgot to answer you question.
    It looks like you could have the 315 or 434 MHz
    The antenna length for
    315 MHz = 22.63 cm
    434 MHz = 16.43 cm
    The above figures are just "ball park" starting lengths. Use the one for your frequency and even with out a good ground plane you should see improvement.
    Mar 2008
    Hello Steve,
    Since I still receive noise..I decide to use Holtek encoder/decoder which is HT12E/HT12D. I construct the circuit following your advice and connect all data pins at HT12E/HT12D to port A0-PortA3.The decoder works fine but the encoder have a little bit problem.That's why I'm not receiving any signal because When I check OSC pin at encoder using logic probe,it show logic low at OSC 1 and show nothing at OSC 2.For your Information, I put 1M resistor between these 2 pins. Don't know what's really happen with my encoder. If you have any idea about the problem..can you please share it with me??
    I never used those ICs... maybe you could some something in this document
    http://rentron.com/remote_control/remotes.pdf
    It show different value for the resistor. I didn't read the according datasheet to see if it affect anything though.
    Maybe you screw the OSC signal with your probe.. use a scope instead, set your probe to 10X (or 100X if you have any) and see what happen.
    TE pin should be tied low too unless the oscillator won't run.. as per Their Block Diagram (page 2) in their datasheet.
    http://www.holtek.com/pdf/consumer/2_12ev110.pdf
    As usual, Before you attach your RF modules, try direct connection, Dout to Din of your Holtek ICs.
    HTH
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
