problem with sending data using RF module
Results 1 to 40 of 52
Threaded View
  1. #27
    Mar 2008
    Texas, USA
    Check your comp drawing. If it's correct, you're sending the comp to rails. I think you ment to take the output of the rec to the inverting input, not ground. The 100uf cap is a bit much. I'd use a 1uf or even a .1uf.
    Also, what's the signal look like at 1.8khz (same speed as the tx). Your receiving scope pix says you'r reading at 19.3mhz. If your data is riding on the noise at 1.8khz, you'll need to filter the noise in a LF band pass amp.
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
