PCB low volume production
Results 1 to 37 of 37
    Jan 2007
    Default PCB low volume production
    Hello, I know, that this is out of the scope of this forum, but maybe someone could help me here:
    I will need to produce low volume of pcb boards (20 / 30) PCS, and I am looking for the cheap company (e.g. from China) which could do the job. Does anyone could suggest to me some company?
    Thanks...
    I have used this company here in the uk and they are very cheap and I think you will struggle to beat his prices, I had 100 Double sided plated through holes,solder mask and slik screen (75mmX65MM) and it only cost £131.00 + vat for the hundered no set up costs, Yes the price may go up if you have less
    http://www.tecbridgecircuits.co.uk/index.htm
    From China, lol. Good luck there my friend getting a company from China to produce a whoping 20-30 boards. They usually start around the 1,000s of pieces and above. We use PCB Express for our prototypes. They are fast and located somewhere in the US.
    I've heard few time PCBCart... not sure how good they are.
    http://www.pcbcart.com/
    I use www.pcbexpress.com, panelize the pcbs onto a big sheet, then cut them up myself. And the best thing (IMO) is that they take raw Protel .PCB files so I don't have to mess with getting the correct gerber format.
    malc-c's Avatar
    malc-c Guest
    Olimex are Ok for hobby boards. Last time I used them they charged $35 for a standard Eurocard SS fibre 1.5mm board, incl cutting, silk screen and solder mask. I was able to get 10 interface boards out of this, but the quality was not what i would call "retail" quality.
    Jul 2008
    China
    Default You can try to use UWELPCB from China supplier
    hello Friends,
    You can try to use UWELLPCB which is from China PCB supplier. quick-turn protopye, to product PCB, rigid PCB, Flex pcb, Rigid-Flex PCB......they have Good price, high quanlity,wonderful service.lower price for the customer.
    their website
    http://www.uwellpcb.com
    Quote Originally Posted by uwellpcb View Post
    hello Friends,
    their website
    You have to give China's business community their due, they are on their toes in the hunt for business.
    hello Friends,
    their website
    Ever notice that they usually talk in the third person while promoting their own interests?
    Sep 2007
    USA, CA
    Yeah, those posts should be deleted as SPAM. That is the only time that guy has posted, and in an OLD thread. I'll bet they have a google watch to send them sites with their keywords, and it's just a bit slow.
    Jul 2008
    China
    oh, Friends. We just release an information about PCB fabrication to you guys. When you use us, we can help you to get more competitive on your business.
    www.uwellpcb.com
    Sendy
    May 2007
    Republic Serbia
    Default help for you
    I can offer to make you PCB but only one side with top stamp and soldermask and hole's for minimum cost + transport cost.
    You can send me Protel99SE,Altium or SprinLayout 5 files or simple PDF format.
    Contact me on my private email.
    Cost is 6 EUR for 1dm² it is price for 1-10 pcs if you need more price go to
    10-100 = 4 EUR for 1dm²
    I can make PCB with minimum lines 0.3mm and pad distance minimum 0.3mm.
    Top stamp can be only white and soldermask green.
    If someone need let me know.
    Regards Robert
    Try here.
    http://www.futurlec.com/PCBService.shtml
    I did order from them, Price was good but took a bit longer than it should have.
    Victor
    Dec 2005
    Quote Originally Posted by victorf57 View Post
    Try here.
    Victor
    Their prices are much higher than China. They want $267 for 25 double sided 4.25" x 3.00" boards with silkscreen and soldermask. PCBCart (China) wants $153 for the same. Reorders would be $50 less (tooling charge) from China but only half that from Futurelec. Both are quoted in $US.
    Dec 2005
    For those interested, I received the quote from UWELLPCB for 100 pcs. 4.250"x3.000" boards with them supplying and installing about 50 SMD capacitors/resistors/inductors (mostly 805), 2 SOIC-8, 2 SOIC-16 plus a through-hole crystal and a 40-pin DIP socket. They will cost about $22.50 each which includes fabricating the boards, buying and installing the components and air courier charges. I can reduce that more by giving them an annual order from which they will release monthly shipments.
    I have a stencil for the solder paste and have been assembling these myself, inserting the components with tweezers. The last batch of four took 2 hours or 30 minutes per board. The bare boards cost me about $4 each (from PCBCart) and the components about $8 per board. Their prices seem very reasonable to me and fit within my price structure for the product.
    Feb 2009
    Default pcb designe
    dear i read your request. i want to help you if you want? i will make pcb for your circuit if you send me circuit schmatic. also tell me single side or double side designe
    my e mail addres is [[email protected]
    madwolf's Avatar
    madwolf Guest
    Default Re: pcb designe
    i recommand 2 here...pcbtrain and pcbfinpo... i guess it really depends on where you need them...as for me ... i had this order once needs to be sent out to toronto in canada ...so i went for pcbfinpo as its leadtime is shorter and the boards were delivered to the door 3 days after..they got this fancy calculation online but the quantity seems a bit less...and if u don't like to deal with mails then go for them ... on the other hand..pcbtrain can read autocad not only the gerber file...so that is a plus for the british side...i luv them both more than those made in china products...no offense or anything but...they disappointed me twice out of 3 time orders...
    www.pcbtrain.co.uk and www.pcbfinpo.com
    hope it helps bro...
    WUOOOOOOOO
    tonyliu's Avatar
    tonyliu Guest
    Default Re: PCB low volume production
    Please always try with us
    We are not PCB manufacturer from mainland of China, we are a EU based trading company focus on purchasing PCB in China.
    PCB Connect has below advantage
    1.PCB Connect had purchased PCB in China for nearly ten years, we are well-known in Chinese PCB market . our group have great purchase power,
    So that we can get very good price &service from our suppliers , so please do not surprise if we can sell cheaper to you compare to the price that
    you buy from our Chinese PCB manufacture directly .
    2.We know the PCB suppliers in China very well , understand their advantage & weakness very well, and we always choose the most suitable ones among
    them , we have regularly audit & Q-meeting with them and we have corrective actions following system .
    3. Compare to doing business with Chinese supplier directly , we always can offer better service , because we understand service is the key value for a trading company .
    4.After factory FQC&FQA checking , PCB Connect have QA to check cosmestic again , for every new Pn we will do the function test include cross section, solderablity test, Thermal shock test etc , we can say our quality of the PCB boards is better than the quality that you buy from Chinese PCB manufacture directly.
    Tony Liu
    Sales Manager
    __________________________________________________ _______________________
    PCB Connect China
    Tel: +86(0)755 2332 6426
    Fax: +86 (0)755 2341 5423
    Mob: +86 (0)13410265448
    [email protected]
    www.pcbconnect.se
    Skype: pcbconnectab.tony
    Head office: Fagerstagatan 15, 16353, Spanga, Sweden
    Jan 2006
    Istanbul
    We are looking for a pick & place machine that supports 540mm x 540mm pcb size.
    If anyone knows a company that makes such machine, please post its information.
    Quote Originally Posted by sayzer View Post
    W-kidi R600 and W-kidi R580 are auto pick and place which is capability to carry over 540mm. W-kidi is OEM well known factory. free shipping worldwide is available for most countries. For more information please see our signature below for the link.
    The BGA Store USA
    theBGAstation.com
    May 2016
    I am buying boards from Bay Area Circuits for prototype boards; they do a very good job; I use the free software DipTrace and it links to Bar Area Circuits automatically when you buy from a menu within DipTrace; I bought 2 boards for $15 each, I don't know how much the price drops for 30 pieces.
    Aug 2016
    Also you can find Good PCB product from PCBcart.
    Oct 2009
    I've been using PCBWAY for the last half a dozen projects. Turn-around is quick, boards are great and service top notch
    Apr 2017
    Thumbs up Re: PCB low volume production
    [/ QUOTE]
    Your photo looks good, you buy a separate board or finished product?
    Oct 2009
    Their minimum order is five boards of one design. That was my finished project
  1. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  2. Low Volume PCB House?
    By Normnet in forum Off Topic
    Last Post: - 22nd November 2008, 16:39
  3. pt2258+16f877 how can i use for 5.1 volume control ?
    By whyliving in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 18:51
  4. Problems with RC2 and RC3
    Last Post: - 29th May 2006, 18:19
  5. 4-line LCD Help - using PortA instead of B
    Last Post: - 31st March 2005, 04:14
