Hi.
Could somone tell me what should be the values for External weak pullups.
I'm using 10K but I thing it is too much. I read somewere I should use 4.7K.
So what value should I use to be safe?
My second question:
Do I need to use external pulldown resistors on pins that are default LOW.
Let's say I want RA5 on PIC16F684 to be low by default oce I disable internalm wpu, should I use an external weak pull down resistor to tie it to ground? If yes, what value?
My third question:
Should use a RC networks (0.1 capa with an external resistor for weak pull ups or just a resistor?
I've seen that in some circuit, the designer used a 47 UF capacitor on his 7.2V power supply for supplying a circuit with a PIC16F684. Why would he use this capacitor as the current is DC?? Is it needed to filter something or to prevent some voltage loss or something?
Thanks for any replies !!!
PM or e-mail....
