Gps/glcd
Results 1 to 3 of 3
Thread: Gps/glcd
    Mar 2008
    Default Gps/glcd
    Has anyone any ideas how to use a gps module and connect it to a GLCD?
    What I'm hoping to do (somehow) is have the whole of the left hand side of the GLCD show the SPEED of the vehicle I'm travelling in (car) while the right hand side is split into 4 lines, 2 lines will only display one of maybe 3 words each depending on which input is active on the pic, while the other 2 lines will be a bargraph display displaying the level in the fuel tank.
    Any ideas anyone? or would I be better off using a 2X16 or 4X 20 LCD display and just using LED's to display the speed decoded from the GPS unit?
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by karenhornby View Post
    Has anyone any ideas how to use a gps module and connect it to a GLCD?..........
    http://www.picbasic.co.uk/forum/show...ighlight=nokia
    Mar 2008
    Gerogetown, Texas
    What GLCD are you going to use? I have some code I used a few years ago to log GPS data to a eeprom and display the data on a character LCD. It would be easy to port that code to a GLCD. The code is a little sloppy but I think you can get the idea.
    '*  Name    : hand held gps.BAS                                 *
    '*  Author  : Dave Cutliff                                      *
    '*  Notice  : Copyright (c) 2002 Use at your own risk           *
    '*  Date    : 9/8/02                                           *
    '*  Version : 3.0                                               *
    'LCD Setup
    DEFINE LCD_DREG     PORTB
    DEFINE LCD_DBIT     4
    DEFINE LCD_RSREG    PORTB
    DEFINE LCD_RSBIT    1
    DEFINE LCD_EREG     PORTB
    DEFINE LCD_EBIT     3
    DEFINE LCD_BITS     4
    DEFINE LCD_LINES    2
    DEFINE LCD_COMMANDUS    2000
    DEFINE LCD_DATAUS   50
    Cont        CON %10100000
    vol_addr    CON 0
    first_addr  CON 2
    CMCON = 7
    'VRCON = 0
    'Set up Serial port
    SerPin  VAR PORTA.2
    SerPout VAR PORTA.3
    GPSIN   VAR PORTB.2
    EECLR   VAR WORD
    A       VAR BYTE
    B       VAR BYTE
    G       var byte
    n       VAR BYTE
    C       VAR WORD
    D       VAR BYTE
    D1       VAR BYTE
    E       VAR BYTE
    E1      VAR BYTE
    Cse     VAR BYTE(3) 'Whole number course (no decimal)
    Spd     VAR BYTE(3) 'Whole number speed in kts.(no decimal)
    gdat    VAR BYTE(60)
    cnt     VAR BYTE
    volume  VAR WORD
    addr    VAR WORD
    LOGDAT  VAR BYTE '(32)
    OLD1    VAR BYTE
    NEW1    VAR BYTE
    Temp1   VAR BYTE
    response    VAR BYTE
    Encodercnt  VAR BYTE
    N_      VAR OLD1.BIT4
    O_      VAR NEW1.BIT5
    INPUT PORTA.4       'ENCODER a
    INPUT PORTA.5       'ENCODER b
    INPUT PORTB.0       'ENCODER SWITCH
    'status  VAR BYTE  'GPS status, A = good data, V = bad data
    NEW1 = PORTA & %00110000
    OLD1 = NEW1
    Encodercnt = 1
         'LOG DATA VIA RB.0 INTERRUPT
    INTCON =$90      'RB.0 INTERRPT NEG TRIGGER
    OPTION_REG.6 = 0
    GOTO START
    DISABLE
    log:
    addr = (volume * 36) + 2    'append address
    FOR A = 0 TO 35
    I2CWRITE porta.1,porta.0,cont,addr,[gdat(A)] 'write GPS data
    PAUSE 10
    addr = ADDR + 1
    NEXT A
    VOLUME = VOLUME + 1
    I2CWRITE porta.1,porta.0,cont,0,[VOLUME]    'write new address count
    PAUSE 10
    INTCON.1 = 0
    RESUME
    ENABLE
    Start:
     cnt = 0
     PAUSE 1000
     LCDOUT $fe,1   'clear lcd
     LCDOUT $fe,2   'home
     LCDOUT $fe,$0c 'Curser off
     I2CREAD PORTA.1,PORTA.0,CONT,0,[VOLUME] 'the eeprom reverses the upper
     PAUSE 10                                ' and lower bytes of the "volume"
     D = VOLUME.BYTE1                        ' word. These vars put the word
     E = VOLUME.BYTE0                        ' back in the correct order
     D1 = E
     E1 = D
     VOLUME.BYTE1 = D1
     VOLUME.BYTE0 = E1
     LCDOUT "EPROM HAS ",HEX VOLUME," BYTES"
    IF VOLUME = 0 THEN GET_DATA         'no saved data get data
    IF PORTB.0 = 0 THEN GET_DATA        'bypass serial by pushing button
    ON INTERRUPT GOTO log      'LOG DATA VIA RB.0 INTERRUPT
      has_data:
      LCDOUT $fe,2   'home
      PAUSE 250
      SEROUT2 SerPout,188,["1  Clear EEProm", 10, 13]   'send PC instructions
      SEROUT2 SerPout,188,["2  Append data", 10, 13]
      SEROUT2 SerPout,188,["3  Read data log", 10, 13]
      SERIN2 serpin,188,[DEC1 response]                 ' PC response
      if response < 1 or response > 3 then has_data
      branchL response,[NOP,Clear_EEProm,get_data,Read_EE] 'process response
      GOTO has_data
    get_data:
     'ENABLE 'SEROUT2 SerPout,188,["1 "]
     gosub CHK_ENCODER1
     OLD1 = NEW1
     if portb.0 = 0 then gosub log 'if the switch is pressed log data
     'serin2 SERPIN,188,2000,no_data,[wait("$GPGGA,"),str gdat\35\"*"]  'FOR TESTING W/O GPS CONNECTED
     serin2 GPSIN,188,2000,no_data,[wait("$GPGGA,"),str gdat\60\"*"]   ' FOR RUNNING WITH GPS CONNECTED
     'serout2 serpout,188,["$GPRMC," ,gdat(0),gdat (1),gdat(2),gdat (3),gdat(4),gdat(5),_
     'gdat(6),gdat(7),",A,",gdat(8),gdat(9),gdat(10),gdat(11),gdat(12),gdat(13),_
     'gdat(14),gdat(15),gdat(16),gdat(17),gdat(18),gdat (19),gdat(20),gdat(21),gdat(22),gdat(23),_
     'gdat(24),gdat(25),gdat(26),gdat(27),gdat(28),gdat(29),gdat(30)]
     'SEROUT2 SERPOUT, 188,[13,10]
     gosub GPSOUT
    GOTO good_fix
    bad_fix:
     LCDOUT $fe,2   'home
     LCDOUT "   Bad Data    "
      GOTO get_data
    good_fix:
    branchL Encodercnt,[NOP,latout,tout,Sat_dat] 'process encoder changes
    GOTO get_data
    NOP:        'PLACE HOLDER
    GOTO get_data
    no_data:
     LCDOUT $fe,1
     LCDOUT $fe,2
     LCDOUT "     No Data    "
    cnt = 0
    GOTO get_data
    Sat_dat:            'Number of sats received and quality
     LCDOUT $fe,1
     LCDOUT $fe,2
     LCDOUT "Recp Quality ",gdat(32)
    LCDOUT $fe,$C0
    LCDOUT "Sat's received ",gdat(34)
    PAUSE 500
    GOTO get_data
    tout:               ' Time
    LCDOUT $fe,1
    LCDOUT $fe,2
    cnt = cnt + 1
    LCDOUT "  ",gdat(0),gdat (1), ":",gdat(2),gdat (3), ":",gdat(4),gdat(5)
    GOTO get_data
    latout:         'lat and long data
    LCDOUT $fe,1
    LCDOUT $fe,2
    cnt = cnt + 1
    LCDOUT " ",gdat(9),gdat(10),%11011111,gdat (11),_
    gdat(12),gdat(13),gdat(14),gdat(15),gdat(16), " ",gdat(18)
    LCDOUT $fe,$C0
    LCDOUT gdat(20),gdat(21),gdat(22),%11011111,gdat(23),gdat(24),gdat(25),_
    gdat(26),gdat(27),gdat(28)," ",gdat(30)
    PAUSE 500
    GOTO get_data
    '**********Write to EEprom**********************************************
    Clear_EEProm:
    LCDOUT "CLEARING EE"
    FOR EECLR = 0 TO VOLUME * 37        'sets range to clear
    I2CWRITE porta.1,porta.0,cont,EECLR,[$0]    'write zeros
    PAUSE 10
    NEXT EECLR
    VOLUME = 0
    I2CWRITE porta.1,porta.0,cont,0,[VOLUME]    'write volume zero
    PAUSE 10
    SEROUT2 SerPout,188,["VOLUME ", HEX volume,10,13]
    LCDOUT "VOLUME", HEX VOLUME
    PAUSE 1000
    LCDOUT $fe,1
    'NEXT A
    GOTO get_data
    GPSOUT:
    serout2 serpout,188,["$GPGGA," ]
    for G = 0 to 60
    serout2 serpout,188,[gdat(G)]
    next G
    'SEROUT2 SERPOUT, 188,[",A,"]
    'for G = 8 to 30
    'serout2 serpout,188,[gdat(G)]
    'next G
    '***********Read EEProm*************************************************
    Read_EE:
    B = 0  'line counter
    FOR C = 2 TO VOLUME * 36    'address range
    ADDR = C
    I2CREAD PORTA.1,PORTA.0,CONT,ADDR,[LOGDAT]
    PAUSE 10
    SEROUT2 SERPOUT, 188,[LOGDAT]
    B = B + 1
    IF B = 36 THEN GOSUB END_LINE   'put carrage return and line feed
    NEXT C
    GOTO GET_DATA
    END_LINE:
    SEROUT2 SERPOUT, 188,[13,10] 'put carrage retun and line feed at end of line
    B=0
    CHK_ENCODER1:
            NEW1 = PORTA & %00110000    'read porta
            If NEW1 = OLD1 Then RETURN  'if no change return
            Temp1 = N_ ^ O_             'XOR bits to determine direction
            If Temp1 = 1 Then GoTo Inc1 '  if 1 then incroment
            Encodercnt = Encodercnt - 1 'decroment counter
            if Encodercnt < 1 then Encodercnt = 3   'max count  = 3 change to add pages
    Inc1:
           Encodercnt = Encodercnt + 1  'incoment counter
           if Encodercnt = 4 then Encodercnt = 1    'set min number
