Stepper motor with L293B and pic16f648A
Results 1 to 4 of 4
    Jan 2008
    Default Stepper motor with L293B and pic16f648A
    Hi.
    Im trying to make a stepper motor move right or left with this pic.
    I've connected everything according to examples and the datasheets but still no movement.
    i guess its my code and im missing something. i would really appreciate if someone can please point me in the right direction.
    DEFINE ADC_CLOCK 3
    steps var word
    stepArray var byte(4)
    CMCON = 7
    TRISA = 1
    TRISB = %11110000
    PORTB = %11111111
    input porta.0
    input porta.1
    stepArray[0] = %00001010
    stepArray[1] = %00000110
    stepArray[2] = %00000101
    stepArray[3] = %00001001
    if porta.1 = 1 then
    steps = steps + 1
    if porta.0 = 1 then
    steps = steps -1
    PORTB = stepArray[steps // 4]
    pause 3
    the motor is connected on port b - 0-3 and the buttons are on pins a0 and a1
    anyone?
    thanks in advance,
    Shahar
    Sep 2006
    Mexico
    Hello, try with this modified code:
    DEFINE OSC 4    'Change it for your osc
    DEFINE ADC_CLOCK 3
    steps var word
    x var byte
    CMCON = 7
    TRISA = %00000011   'Porta.0 and porta.1 as input
    TRISB = %00000000   'Portb as output, 0=Output, 1=Input
    PORTB = 0
    x=0
    'input porta.0      ' You dont need this, just TRISA command
    'input porta.1
    if porta.1 = 1 then
         for x=0 to 3
    PORTB = stepArray[x]
    pause 20 'Change it for diferent speed
    next x
    if porta.0 = 1 then
    for x=0 to 3
    PORTB = stepArray[3-x]
    next x
    Jan 2008
    Default Not there yet...
    Thanks Raflex but it still doesnt work. when i use this program with the simulator it gets nothing - the stepper motor isnt even getting ready and all PORTB is not an output.
    when i used the original code - i saw the motor getting ready (green) but when i pressed the button - it didnt do anything.
    anyone?
    Sep 2006
    Mexico
    Quote Originally Posted by manjero View Post
    anyone?
    Check the configuration fuses, mclr, internal or external osc, etc:
    @ DEVICE pic16F648a, INTRC_OSC_NOCLKOUT
    ' System Clock Options (HS_OSC, INTRC_OSC, INTRC_OSC_NOCLKOUT)
    @ DEVICE pic16F648a, WDT_OFF
    ' Watchdog Timer
    @ DEVICE pic16F648a, PWRT_OFF
    ' Power-On Timer
    @ DEVICE pic16F648a, MCLR_OFF
    ' Master Clear Options (External)
    @ DEVICE pic16F648a, BOD_ON
    ' Brown-Out Detect
    @ DEVICE pic16F648a, LVP_OFF
    ' Low-Voltage Programming
    @ DEVICE pic16F648a, CPD_OFF
    ' Data Memory Code Protect
    @ DEVICE pic16F648a, PROTECT_OFF
    ' Program Code Protection
