Motion Tracking
Results 1 to 6 of 6
Thread: Motion Tracking
    Nov 2004
    Default Motion Tracking
    I've been asked to design a system which will reliably track a person walking back and forth across a room, and move a video projector back and forth so that the center of the projected image is (more or less) located on the center of the person's body.
    It's for a Modern Dance installation.
    Picture a video projector mounted on the head of a standard photographic tripod and you'll have a good idea of what I have in mind.
    The projector will have to pan back and forth over a 100 degree arc, but won't need to tilt up or down. Control will be via geared steppers & position sensors, or plain servomotors. And trapezoidal accelleration curves and all that.
    I've considered having the performer wear a bracelet or belt containing several high-powered IR LEDs. I could then mount a generic video camera on top of the projector so that they move together. An IR filter on the front of the camera would let me only 'see' the bright spot.
    If I can capture the video signal 5-10x per second and break it down to it's basic pixel elements, I can then send pan the projector back and forth until the captured hot spot matches the 'x = halfway' position in the pixel matrix.
    Thus, the center of the projected image will more or less match the X position of the dancer's belt/bracelet.
    What am I missing? Is there an easier way to do this?
    Thoughts?
    John
    Dec 2003
    Wichita KS
    How about heat sensors? If mounted on a rotatable hinge, set off my about 30 degrees. Kinda like the following:
    ___
    Object.
    measuring each of the devices, one will probably show more "heat" than another, and turn the camera to that direction. When they are equal , they are in the middle.
    I have never done something like this before... Maybe someone has, and can say "Dwayne aint going to work" or come up with a much better idea than mine.
    I think you can get infrared heat sensors at cheap store for next to nothing.
    Dwayne
    Ability to Fly:
    Hurling yourself towards the ground, and missing.
    Engineers that Contribute to flying:
    Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute
    Pilots that are Flying:
    Those who know their limitations, and respect the green side of the grass...
    Nov 2004
    I've thought about heat sensors, actually.
    The faculty I'm working with on this wants a bit more precision than just 'point it at the warm blob over there.' How much precision do you think I can get with those devices?
    Ultrasound would work if I only need to pan back and forth. I pulled some nice papers yesterday that talk about localizing a source based on a plane wave arriving at two closely spaced detectors. Depending on the location of the source, the detectors will receive the same signal either in phase, out of phase, or something in the middle.
    So the source of a train of pings would be fairly easy to calculate.
    If I mount the whole mess fairly close to the ground plane, I can avoid a lot of ambient reflections - similar to how a PZM microphone works.
    Unfortunately, it looks like she may want the projector to tilt as well. Which either means moving to a video based system where I can look for a hot spot, or add a second ultrasound sensor pair mounted perpendicular to the first so I can calculate the angle above and below a plane.
    ....X
    .X....X
    ....X
    JEC
    New England
    It would be a whole mess of wiring - but how about a grid of pressure sensitive strips (used for industrial control/automation) - or maybe a grid of active IR 'beams'.
    Arch
    Dec 2003
    Wichita KS
    Hello JEC,
    JEC>>How much precision do you think I can get with those devices?<<
    I don't know... But I would venture to guess you can become fairly accurate with them. I have a friend that has experience with them... I will ask.
    Dwayne
    Ability to Fly:
    Unfortunately GPS are not so accurate as you want .... i'm joking
    for sure a load of infraled emmiter and receiver in an matrix config will do the job. Acting like touchsceen. but what about the dimension of the sceen ???
  1. Motion Capturing
    By koossa in forum Off Topic
    Last Post: - 30th June 2009, 12:05
  2. Easy to program motion sensor
    By g-hoot in forum Adverts
    Last Post: - 16th April 2009, 04:36
  3. A/D on 16F767 for light tracking.
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 10th November 2007, 06:56
  4. Suggest a motion sensor Please
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 14:22
  5. Replies: 5
    Last Post: - 1st February 2006, 03:13
