Using PIC16F88 oscillator as oscillator for other ICs
Results 1 to 11 of 11
    Mar 2008
    Default Using PIC16F88 oscillator as oscillator for other ICs
    Hi there. I'm an undergrad in the mechanical engineering department at CSU, working on a class project. Amongst the things going into this are a keypad and an LCD. As I can't spare the pins to run either of them directly off the pic, I chose to use an EDE702 LCD controller and an EDE1144 keypad encoder.
    However, both of these components require a 4Mhz external oscillator, which I forgot to purchase and now have neither the time to wait for them, nor the money to pay overnight shipping. Fortunately, I've heard that you can run an output off the PIC to serve as a direct TTL clock signal, but I have no idea how to do this and my own research into the matter has not been fruitful. If anyone can offer me any insight, it would be greatly appreciated.
    Quote Originally Posted by Torael_7 View Post
    {SIGH}
    http://www.picbasic.co.uk/forum/show...ing+oscillator
    A simple search got that one...try it...you'll like it...
    Mar 2008
    {SIGH}
    What?
    Okay, I'll admit to having not done a search before I posted...sorry. All the answers from that thread look to be driving multiple PIC's off one oscillator crystal, which I lack. Is the basic idea just the same, ie, run OSC2 into OSC1?
    Read the thread skimask pointed to carefully , and yes it is the same idea. Set the osc mode to clockout and it should work. (disclaimer: I have not tried it with your parts )
    What?
    It's the same story over and over again...and it usually begins with something like "I am a student, 18th year of Engineering 101 and my class project is to build the next best greatest particle accelerator ever designed." Then it goes on with a story, then finally ends up with something I somehow figure would be a simple task for somebody who has been in any Engineering study at all "I need a 5v power supply for X. Has anybody ever built one?"
    Depending on how it's set up, OSC2 might be OSC1/4, so you get 1Mhz out of 4Mhz. The easiest thing I can think of off the top of my head is to feed all inputs of a 7404 hex inverter (or any logic gate for that matter, use a 2-input Quad AND, or OR, or NOR, or NAND gate chip with the inputs tied together and tie all of the inputs together, whatever works) with a single oscillator, and use the outputs as your clock out. A million different ways to do it....
    We're talking for nothing as we don't know what others chip are... and how they communicate.
    If both are 16F88... and the timing is not as this critical, why not using the internal OSC and have 2 spare I/O on each for free.. but we still don't know how timing critical your app is
    OK i hear some saying that they used internal OSC and NEVER EVER had any problem even with 115,200 baud ser com...... yeah right
    Talking leave the guns at the Cloakroom, please !!!
    For ALL my PicBasic Forum Helping Friends ...
    EDE 702 and 1144 are PICs programmed for special purposes ...
    Sooo, using the same clock for them all is described in the relevant AN from µChip ...
    so simple as that
    PS : having read the DS 40040B AN could have spared one EDE 1144 ... Serial to Parallell PIC Converter for LCD ( 16F84 ... LOL ! ) could have being found on the Web ... EDE 702 Spared ... ALSO.
  1. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 00:13
  2. Ghange code from PIC16F877A to PIC16F88
    Last Post: - 12th March 2008, 16:09
  3. Pic16f88
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 28th March 2007, 22:27
  4. Replies: 8
    Last Post: - 7th December 2006, 15:42
  5. PIC16F88 problem with TOGGLE command?
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 17th September 2006, 23:31
