PIC and MAX232 in/out
Results 1 to 11 of 11
    Jun 2007
    Mansfield, UK
    I have been reading about RS485. It looks like i need a special converter between my PC and the chips (RS232 > RS485 converter). Would it just be easier to continue with RS232 but not allow any of the PICs to act as a master? If im going to need extra hardware to RS485 anyway then i might aswell have a small box that acts as the master. Thinking about it this might be the best way
    With RS485 you would need a driver chip at both ends.
    The other good thing about 485 over 232 is the 485 can handle longer distances with more reliability. If you do go this way and do not need multiple drops, RS422 is good.
    As far as the best way to go for you system is hard to say. I do not fully understand your system and what you want it to do.
    Just giving suggestions
    Jun 2007
    Mansfield, UK
    Ok, Ill give a description of it.
    As said before these will go into disco lights. There will be at least 14 lights that all have to run together. The addressing system allows for about 200 lights but realisticly i will never have more than 30. They are connected using 3 pin DMX cables. Inside each light the in/out XLR sockets are wired together (asif the light wasnt even there). Most of the lights will be connected with 1 meter cables but PC>first light and stageleft>stageright could be upto 20 meters
    The DataOut pin is only so the lights can send info back to the PC. Things like its ID number so the PC can check all the lights are responding etc.
    DataIn is where the data comes into the lights from the PC to tell them what to do.
    There is a button on the back of each light. When you press it it checks if the PC is sending an ID. If it is then it changes its own ID to the one the PC sent. If the PC doesnt send an ID then it turns itself into a master where it sends data out of DataIn to all the other lights
    The lights need to support PWM for fading.
    They do need to work with some existing controllers too. The existing ones are RS232 but they dont need to send data to these so the RS232 output from the PC could go directly to the existing ones then into a converter for RS485/422 and onto the new ones.
    Since there will be at least 14 lights i think that means i need 485 and not 422. Will i be able to buy an RS232<>RS485 converter and simply swap the MAX232 chips for a MAX485 (if they existst)? Ive not actually made the circuits yet so i can change pins around if i need to
  1. Direct PIC to PC without MAX232
    By acjacques in forum Serial
    Last Post: - 23rd October 2014, 22:32
  2. Interface Pic --> Max232 --> GSM Modem
    By SangkiMangki in forum GSM
    Last Post: - 28th September 2013, 13:57
  3. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  4. Reading PIC serout in hyperterminal
    By financecatalyst in forum Schematics
    Last Post: - 22nd October 2009, 16:13
  5. help my bluetooth and PIC 16F877A?
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 07:52
