I2C Comm with Digital Compass HMC6352
Results 1 to 11 of 11
Threaded View
    Mar 2008
    Default I2C Comm with Digital Compass HMC6352
    This is my first post to the group.
    I'm designing a heading hold autopilot for a free flight glider. I'm basing it on a PIC16F88, and using an HMC6352 digital compass (http://www.sparkfun.com/datasheets/C...ts/HMC6352.pdf).
    I've never played with I2C before, and figured that I would try something simple first, like reading an EEPROM register in the compass module. My problem is that no matter what I do, I seem to always read back a value that is exactly 1/2 of what it should be.
    So then I tried writting a value to a RAM address and reading it back. Again, same issue, the value read back is 1/2 the value written.
    I'm using PIC BASIC PRO, on a LABX18 development board. Here's the code I'm using for the EEPROM read, which is modified from some of the example programs:
    Define  LCD_DREG        PORTA
    Define  LCD_DBIT        0
    Define  LCD_RSREG       PORTB
    Define  LCD_RSBIT       6
    Define  LCD_EREG        PORTB
    Define  LCD_EBIT        3
    ' Define I2C Interface
    SDA    Var    PORTB.1                    ' Data pin
    SCL    Var    PORTB.4                    ' Clock pin
    cmd  Var Byte
    addr Var Byte
    cont Var Byte
        ANSEL = 0                      ' PORTA is digital
        CMCON = 7                      ' PORTA is digital
        Pause 100                    ' Wait for LCD to start up
    loop1:
        pauseus 1000
        cmd = $72                    ' Read from compass EEPROM
        addr= $00                    ' EPROM address $00
        I2CWRITE SDA, SCL, $42, [cmd, addr], nowrite
        pauseus 1000
         I2CREAD SDA, SCL, $42, [cont], noread
        Lcdout $fe, 1, "Data: ", cont
        goto loop1
    nowrite:
        Lcdout $fe, 1, "Write Err"
        goto nowrite
    noread:
        Lcdout $fe, 1, "Read Err"
        goto noread
    If anyone can point me to the error of my ways, it would be greatly appreciated.
    John Ihlein
    Albuqueruqe, NM
    Last edited by ScaleRobotics; - 26th May 2010 at 17:07. Reason: code brackets added
  1. I2C Master/Slave 16F88/16F767 working code
  2. HARDWARE I2C SAMPLE CODE question
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 19:33
  4. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  5. Digital Compass Project
    By BJSmith in forum Serial
    Last Post: - 7th April 2006, 19:32
