Need suggestions for noise suppression
Results 1 to 3 of 3
    Default Need suggestions for noise suppression
    I'm working on a fairly simple lighting controller operated from batteries and an FM Radio Control type receiver. I've got the code and circuit working but am getting a significant amount of radio noise induced from the circuit (pic below) into the receiver. I did some searching on this forum, mostly stuff I found is about reducing noise into the PICs, I'm trying to reduce the noise out. I've tried ferrite beads (large enough to coil the signal wires through several times) and those only helped a little but the noise is still significant. Without the circuit attached to the receiver, I am getting full normal range with no noise.
    I'm using a 12F683 and the transistors are simple pnp type transistors. Any suggestions on noise suppression additions to this circuit or techniques to mitigate would be VERY much appreciated.
    Wink Oh oh ...
    Hi, Paul
    Have a look to this project, all you need is here ...
    http://www.rcgroups.com/forums/showa...mentid=1767837
    PS: Welcome aboard !!!
    <Palm smacking forehead>
    An opto isolator! Duh!!!!!
    I feel like an idiot.
    Thanks for the kicker Alain!
  1. Looking for O-scope suggestions / reviews
    By Byte_Butcher in forum Off Topic
    Last Post: - 17th June 2010, 01:24
  2. seeking polling suggestions
    By rdxbam in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2009, 22:46
  3. Replies: 3
    Last Post: - 17th April 2007, 15:45
  4. AC Relay EMI Suppression
    By CocaColaKid in forum Schematics
    Last Post: - 4th January 2006, 09:13
  5. Pushbutton code routine suggestions?
    Last Post: - 3rd September 2005, 02:02
