Check once again all peripheral register and also the MSSP section of your datasheet, maybe you have to select a specific mode in X register(s)... 7 bits+start/stop int or something like that.
More tha often the datasheet will give you some tips how to set/use int flags.
I never dared to open your datasheet to check it![]()
