on interupt with pic 16F619
Results 1 to 5 of 5
    Aug 2005
    NC, USA
    Default on interupt with pic 16F619
    I am trying to figure out how to do a interupt. How do I do an interupt on an I2C Flag? I have tried this, but its not working. Thanks, Charlie
    on Interrupt goto myint
    intcon = PIR1.3 'SSPIF
    myint:
    disable
    INTCON.1 = 0 'disable interupt
    'do stuff
    enable
    resume
    Charlie
    Have a look at the example provided in the manual, even if they don't use the same interrupt source, this should give you some tips.
    You could still do a search with ON INTERRUPT within this forum.
    Aug 2005
    NC, USA
    I have searched around some and found some good tips, but have not been able to find the exact interupt I am wanting to do. I have changed the interupt code based on the examples, but I am still not getting the interupt to trigger off the I2C interupt. Thanks, cp
    INTCON.6 = 1 ' PEIE = Peripheral Interrupt Enable bit
    PIR1.3 = 1 ' I2C interrupt enable
    enable
    Check once again all peripheral register and also the MSSP section of your datasheet, maybe you have to select a specific mode in X register(s)... 7 bits+start/stop int or something like that.
    More tha often the datasheet will give you some tips how to set/use int flags.
    I never dared to open your datasheet to check it
    Aug 2005
    NC, USA
    I have read the data sheet and can't seem to find anything. I noticed some other chips have a SSPCON2 register, bit 7 looks like what I need.
    GCEN: General Call Enable bit (In I2C Slave mode only)
    1 = Enable interrupt when a general call address (0000h) is received in the SSPSR
    0 = General call address disabled
    The 16F819 does not have this register. I am stuck with the 18 pin interal osc with some analogs and I2C form, but I would really prefer getting the 16F819 working with an interupt. I have an 16F88, but that also does not have the SSPCON2 register either...
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  3. Replies: 2
    Last Post: - 4th January 2009, 23:35
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
