Need help in matrix keypad coding
Results 1 to 16 of 16
    T.Jackson's Avatar
    T.Jackson Guest
    In other words, I think a fish has been given...and more fish might soon be handed out...
    Don't you go stealing my fish, I'm not very good at sharing
    You got fish? Sounds like a slogan for something...
    Got Fish?
    T.Jackson's Avatar
    T.Jackson Guest
    Got Fish?
    After studying applied reasoning I can't help but wonder if maybe I do.
    Mar 2008
    Smile
    It's ok skimask, I understand what you're trying to say. I'm just new in the world of PIC and know nothing about it.Now I need to deal with PIC to finish my project. So, I just do reverse Engineering..study the codes given and learn how it function.
    May 2008
    Default Ok, now WHY does it work
    All right I've seen this code a bit now and I have to admit I don't know WHY it works. I do know that may or may not work if you change the port (that's informative I know) which might be related to some weak pull up issue (?) or some other circuit design point I missed.
    Here's the question - This code sets all values of the portD to zero
    ' Wait for keypress
    For col = 0 to 3 ' 4 columns in keypad
    PORTD = 0 ' All output pins low
    TRISD = (dcd col) ^ $ff ' Set one column pin to output
    row = PORTD >> 4 ' Read row
    If row != $f Then gotkey ' If any keydown, exit
    then changes the direction of one pin/column at a time to output instead of input. Great. The question is: why by simply changing the pin to output does the value of that pin go from low (portd=0) to high?
    Sep 2007
    USA, CA
    The output state of the pin is stored, even when it is an input. When you make it an input, it automatically goes wherever the input is pulling it. As soon as you make it an output, the old output value is restored.
    The way to ensure it goes to the desired state is to set the value prior to TRISing it to an output.
    May 2008
    Default Thanks
    Ah gotcha. So the column is switched to output, then the rows (which are 4 bits over) are examined to see if that row is linked to the column. Thanks - I don't know how I missed it now that I see it. This should help with a keypad with a different number of buttons I've been working on.
  1. Matrix Keypad routine
    By mister_e in forum Code Examples
    Last Post: - 18th September 2022, 20:30
  2. calculator-like code entry with matrix keypad and display
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 22:58
  3. 3x4 matrix keypad
    By tazntex in forum Serial
    Last Post: - 14th October 2008, 20:13
  4. Inconsistent output on a 4x4 matrix keypad
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 03:54
  5. very basic matrix keypad question
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 21:33
