Need help in matrix keypad coding
Results 1 to 16 of 16
    Quote Originally Posted by rano_zen06 View Post
    D. What i want to do is:-
    when I pressed switch '1' at keypad the character display on lcd is BUS01,
    when I pressed switch '2' at keypad the character display on lcd is BUS02;
    when I pressed switch '3' at keypad the character display on lcd is BUS03
    The problem now, I don't know how to contunie this coding to get what i really want because..................
    So what is it that you really want?
    Is it what's at the beginning of your post?
    What have you tried so far?
    What works?
    What doesn't work?
    try to change the following section
    loop:
            Gosub getkey ' Get a key from the keypad
            Lcdout $FE, $C0, "BUS",DEC2 key ' Display ASCII key number on 2nd line
            PAUSE 200
            Goto loop ' Do it forever
    Mar 2008
    loop:
            PAUSE 200
    THis code works.Thank you for Helping me.
    That codes works, yes.
    But! Did you learn anything from it?
    Mar 2008
    of course, I will learn something from it.Although I'm new with PIC and the coding but I will give a try.
    Rano, don't worry about Skimask. This is his own way to tell you...
    Hi : and: welcome : on : this : forum : . : We : are : glad : to : see : you : here : and : help : you : when : you : need : us : . : This : said : never : hesitate : to : ask : questions : . : Good : luck : !
    Good one...
    What I was getting at was the fact that the O/P said he 'found the code on the internet' and didn't know how to make it do what he needed it to do...suggesting that maybe the O/P dove in head first, maybe without so much as first creating a 'blinky' and working up from there. 'cause quite frankly, that fix up there a couple of posts back is a very basic fix (change should be the operative word here).
    In other words, I think a fish has been given...and more fish might soon be handed out...
  1. Matrix Keypad routine
    By mister_e in forum Code Examples
    Last Post: - 18th September 2022, 21:30
  2. calculator-like code entry with matrix keypad and display
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 23:58
  3. 3x4 matrix keypad
    By tazntex in forum Serial
    Last Post: - 14th October 2008, 21:13
  4. Inconsistent output on a 4x4 matrix keypad
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 04:54
  5. very basic matrix keypad question
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 22:33
