I2C Master Slave issues.
Results 1 to 10 of 10
    Aug 2005
    NC, USA
    Hi. The issue with holding the clock line low is I have multiple slaves, so I don't think the master will get a word in inchwise with all the slaves pulling the clock low...
    Mar 2008
    Texas, USA
    Quote Originally Posted by cpayne View Post
    Yes, with muli slaves that could get nasty. I thought about that but had re-read your first line in the top post and it said 2 pics. I thought this was just a 2 pic i2c system.
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
    Aug 2005
    NC, USA
    Yes, I am trying to get two working for now, then as soon as I get one good slave, I plan on adding...
    Sep 2005
    Campbell, CA
    Maybe I'm missing something, but it looks like you are polling for the Interrupt Staus Bit in MAIN, and when it is set, you go off and read the receive register. Because you are using a polled operation, not an interrupt-driven one, you can't catch data as soon as it arrives. If you use Darrel's Instant Interrupts and make your I2C routine an ISR, you should be able to receive data any time - even halfway through an A/D conversion.
    Charles Linquist
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. Another I2C Slave Routine Problem
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 06:50
  4. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
  5. Replies: 2
    Last Post: - 10th June 2005, 03:34
