writecode - problem - 18F6720
Results 1 to 4 of 4
    Dear Tomasm, you can use PBP to do your code. MPASM will only translate your .bas file into an .hex file to be place into your PIC.
    better for you to update MPLAB to new version 6.6x
    after that you have to do EXACTLY the following instruction to include PBP into MPLAB. This will work
    http://www.melabs.com/support/mplab.htm
    don't forget to reboot !!!
    many regards.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. WRITECODE stores wrong 14-bit word values in FlashMEM
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 26th June 2009, 04:35
  3. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 22:59
  5. weird 12F629/675 problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 7th October 2004, 01:08
