16f88 interrupt
Results 1 to 12 of 12
Thread: 16f88 interrupt
    Quote Originally Posted by tur_bot View Post
    can any one help me please. it s very urgent , it s for my project at uni and i have just a week to finish it.
    thank you
    Sounds to me like you should've started the 'project' for 'UNI' earlier...or maybe get a bit of help from the 'INSTRUCTOR' (if that's what they call them these days...I call them placeholders) or maybe even try some of your CLASSMATES.
    Use another pin to trigger your 'PORTB.4' pin, write code to trigger that pin to trigger the other pin.
    And no, I don't think this will solve your problem. If GOSUB'ing into your interrupt routine is slow, why would triggering an interrupt to go to the interrupt routine work any better? Your program is most likely hanging up in a loop somewhere or something similar making you think that it's not reacting fast enough, whereas triggering an interrupt in hardware may actually jump directly to that code.
    Look for interrupt on change. But you may need to change your current hardware.
    Mar 2008
    london
    Question
    my program is working fine but i just need to learn more about interrupt so i can make it better. by the way i started my project very early but not early enough (last summer).
    about the small piece of code that i m using to learn about interrupt,I managed to improve my code and it s working but not as expected. the interrupt is activated on the falling edge but I want it to be activated on the rising edge.
    i used a pull down resistor on the portb.0 and the main loop is running and when i connect a 5 volts to activate the interrupt nothing happens (everything stops ) but just when the 5 volts is taken off the interrupt runs for 2 second and the program is back to the main loop.
    there is the code:
    @ DEVICE INTRC_OSC, LVP_OFF, WDT_OFF, MCLR_OFF
    OSCCON=%01101000
    ANSEL=%00000000
    CMCON=%00000111
    OPTION_REG.6=1 'Trigger on rising edge
    disable
    clear
    trisa = %11111111
    trisb = %00000000
    'Pause 500 ' Wait for startup
    LOW PORTB.6
    low portb.5
    start:
    goto loop
    On Interrupt Goto UpdateCounter
    INTCON = %10010000 'Enable INTE
    disable
    UpdateCounter:
    high portb.6
    Pause 2000 ' Wait 2 second
    low portb.6
    low PORTB.5
    INTCON.1=0 're-enable interrupts
    resume
    ENABLE
    GOTO loop
    loop:
    high portb.5
    low portb.5
    low PORTB.6
    Goto loop ' Do it forever
    Disable
    can you tell me what i did wrong , why the interrupt is not activated on the rising edge and how can I resolve it ??
    thank you again for your advices ...
    there's a kinda mess in that
    But if you want to trigger an INT0 interrupt, PORTB.0 must be set as an input.
    try this one
            OSCCON=%01101000
            ANSEL=%00000000
            CMCON=%00000111
            trisa = %11111111
            trisb = %00000001
            CounterA    var word
            PORTB=0
            Pause 50 ' Wait for startup
    loop:
            TOGGLE PORTB.5
            gosub dodelay
            Goto loop
    DoDelay:
            for countera=0 to 200
                pause 1
                next
    disable
    UpdateCounter:
            low PORTB.5
            high portb.6
            low portb.6
    resume
    ENABLE
    Mar 2008
    london
    Smile
    try this one
            OSCCON=%01101000
            ANSEL=%00000000
            CMCON=%00000111
            trisa = %11111111
            trisb = %00000001
            CounterA    var word
            PORTB=0
    loop:
            TOGGLE PORTB.5
            gosub dodelay
            Goto loop
    DoDelay:
                pause 1
                next
    disable
    UpdateCounter:
            low PORTB.5
            high portb.6
            low portb.6
    resume
    ENABLE
    thank you very much , it was the trisb=0000001 command that resolved the problem. it works as expected but one more thing is not right, the portb.6 output 1.62 volts when the program goes through interrupt instead of giving a 5 volts output (a good logic one) as expected.
    is it supposed to be like this?????
    thank you again.
    Nope, seems you have a dead I/O, or faulty connections... or a dead output caused by a faulty connection
  1. Can't ID interrupt source with this IntHandler??
  2. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
  3. 16F88 Interrupt
    By sskeet in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 16:51
  4. How to use an Interrupt to drive a menu on 16f88
    Last Post: - 15th March 2005, 02:16
