[QUOTE=skimask;53213]I2cwrite SDA, SCL,$A0,I,[ "T" , "E" , "X" , "T" , "1" ].....
should also work. (not 100% sure, haven't tried myself, but it should work)
What you originally had was an embedded string, which PBP doesn't natively handle. ( "TEXT1" ). A byte array of characters as noted in the post preceeding can be used as a string, but is not really a 'string' as far as PBP is concerned.[/QUOTE
I used this and not work .Read and display step by step only " T " ,first karakter .
test var byte[5]
test[4] = "T"
test[3] = "E"
test[2] = "X"
test[1] = "T"
test[0] = "1"
ADCON1 = 7
TRISB = 0
TRISC = 0
start:
DISABLE INTERRUPT
scriere:
FOR i = 1 TO 20
I2cwrite SDA, SCL,$A0,I,["T","E","S","T","1"]
pause 30
NEXT i
