Accessing I/O from Chuck Hellebuycks book
Results 1 to 5 of 5
    Feb 2008
    Default Accessing I/O from Chuck Hellebuycks book
    I have problems making this programme work. It is from Chuck Hellebuycks book which I am learning from. When I press the switch both leds go off. I have tried leaving adcon1 = 6 off
    I am using 16f84a instead of 16f876
    Init:
    adcon1 = 6 ' Set all PortA to digital I/O
    trisa = %00000001 ' set PortA RA4-RA1 to outputs, RA0 input
    porta = %00000010 ' Set PortA RA1 high to turn on LED1
    ' *** Test the switch state ***
    if portA.0 = 0 then led2 'If switch is pressed then jump to LED2 routine
    PortA.1 = 1 ' Turn LED1 on
    portA.2 = 0 ' Turn LED2 off
    goto Main ' Jump to the top of the main loop
    LED2:
    '*** Turn LED2 on ***
    porta.2 = 1 ' LED2 on
    porta.1 = 0 ' LED1 off
    Thanks to anybody who can help.
    Well sure you have few compilation errors right?
    For a 16F84.. i would check if you have placed some pull-up or pull-down resistor on your push button. Seems you pick up some noise.
    Hi quester,
    After installing the pullups, I would put a short pause in the main and in the sub routine just before the goto main statements, to slow down what's happening enough to see it .
    Not a bad idea... but here, as long as the switch will remain at x level, LEDs will remain the same same level too. It's more like a Toggle switch monitor rather than a PushButton monitor... or toggle LEDs each time you press on a PushButtons.
    Nothing critical in this one, no debouncing, nothing fancy.
    Feb 2008
    Default Now works but with 16f876 not 16f84a
    I have now used 16f876 ( it works ok) instead of 16f84a I did try your sugestions but with no luck so I am going to rebuild with 16f84a again and try another pic.
    Thanks for the help.
    Quester.
    NEW MESSAGE: I have now got it working! I rebuilt the circuit and it worked OK but one of the LEDs wasnt quite going off but I was working from the book PIC in Practice and the circuit did not show a wire to ground from Vss I fitted that and it is now OK.
    Last edited by quester; - 29th March 2008 at 21:31. Reason: Make it clear. plus new message
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. Loop with two motor and 2 sensors
