Code Protection
Results 1 to 3 of 3
Thread: Code Protection
    Default Code Protection
    Hi
    I have a Big Problem I use the IC-Prog Software and ICSP to programming my 16F876.
    I make a Big mistake and I have Activated the option CPD ,now I can not Programming my software on that Chip.
    All the time I see a error on the IC-Prog Software.
    I Read somewhere on the Internet that I can reset this option is that so?!
    Did i have any chance to Deactivate this CPD I try to erase and to write without CPD but its not working.
    Thanks for any Solution.
    Regards Pesti
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Pesticida View Post
    Completely erase the chip first...including all config bits, program space, eeprom, everything.
    Hi Skimask
    Yes I erase all but d'ont work maybe is a error on the ic-prog version 1.06A.
    Regards Pesti
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. Loop with two motor and 2 sensors
    Last Post: - 9th December 2008, 00:40
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 18:20
  4. Making Program Code Space your playground...
  5. Can't remove code protection of 16F88!!!
    Last Post: - 22nd December 2006, 14:18
