Simple Wireless Communication
Results 1 to 7 of 7
    Dec 2007
    Default Simple Wireless Communication
    Hi All,
    I am trying to setup very simple wireless communication between 2 PIC's (preferably 16F628A as they are abundant in my area).
    What i would like to do is when a button is pushed on the "transmitter PIC" a number is sent to the "receiver PIC" (01153001), the number itself contains three groups of numbers which the PIC will recognise. "01" is a valid code (this code must match a code pre programmed in the receiver, so that the transmitter and receivers can be addressed), "15" is a action code (determines what the receiver will do, e.g. turn on light A) and "3001" is the unit code (this code is unique to the transmitting PIC, at this point the receiver should ignore it)
    The transmitter and receiver i have in mind are:
    Transmitter: http://jaycar.com.au/productView.asp?ID=ZW3100
    Receiver: http://jaycar.com.au/productView.asp?ID=ZW3102
    I have used them before on a similar project and they worked perfectly.
    If anyone can help or point me in the right direction that would be great,
    Thanks for your help in advance,
    Jeremy
    use DEC2 and 2 X bytes variable, and probably a last WORD sized one
    HSERIN [DEC2 UnitNumber, DEC2 Action, DEC4 Trash]
    and then you check UnitNumber to see if it fit your requirement.
    Dec 2007
    Hi Mister_E
    I am really quite new to basic and have no clue where to start, i have attached a schematic of what i think the wiring should be (if there is anything wrong please point it out) but apart from that i would not have a clue.
    Are there any similar projects or is this more complicated than i think?
    Jeremy
    Start small. For now, forget the RF module. Do some PIC to PC communication first, then PIC to PIC communication. Once you're done, add the RF modules.
    There's a lot of Serial communication example here. Same for RF.
    Dec 2005
    1. Your schematic says RX Module & Receiver but shows the transmitter.
    2. Don't forget a 0.1µF bypass capacitor on Vdd.
    3. Your question is asked frequently and usually devolves into a long, confused thread. I've put together a very short web page that covers simple wireless communication, including a link to sample PBP code. See...
    Dec 2007
    Hi Dave,
    I made some changes to the schematic to include the capacitor, ideally what i am trying to do is have the transmitter send a code when SW1 is pushed and if that code is the same as the code in the receiver then the LED is turned on.
    I also had a look at your PIC RX-TX code http://davehouston.org/PIC-RX-TX.TXT
    can it be adapted to work on a 16F628A?
    Thank you very much for your time,
    Jeremy
  1. Wireless serial communication question
    By Ahmadabuomar in forum Serial
    Last Post: - 21st December 2009, 03:49
  2. Replies: 0
    Last Post: - 29th August 2008, 14:55
  3. Replies: 2
    Last Post: - 29th September 2007, 06:49
  4. RS 485 wireless communication
    By Armadus in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 19:30
  5. Wireless communication gear.
    By toalan in forum Off Topic
    Last Post: - 17th March 2005, 16:33
