Adc For 16f88
Results 1 to 12 of 12
Thread: Adc For 16f88
    Jun 2006
    Angry
    Quote Originally Posted by Kamikaze47 View Post
    I'm not clear on the problem you are having.
    What is it doing or not doing? And what should it do instead?
    I want to measure the audio input at the left and the right channel of a stereo coder (is for fm transmitter).
    The left channel show on first line and the right channel show on second line on the 2X16 LCD.
    But the LCD first show the left channel and after show the right channel alternately (very fast).
    Perth, Australia
    you may want to change the line:
    LCDOut $fe,1,"L:"
    to:
    LCDOut $fe,1,$fe,2,"L:"
    There's something obvious that just jump to my face. You're using the default LCD assignment, and this use a.0, a.1... which is also your adc channels.
    so unless you forgot something in your copy/paste, or i totally misunderstood something
    EDIT: one more... Assuming you're using the internal OSC, you want to configure it properly... unless the whole beast will run @32KHz
    OSCCON = %01100000 ' 4MHz
    Don't forget to check your maths range... sure it will overflow the max 100 soon.
    Jun 2006
    I use external xtal 4mhz and the below LCD assignment
        DEFINE LCD_DREG PORTB
        DEFINE LCD_DBIT 4
        DEFINE LCD_RSREG PORTB
        DEFINE LCD_RSBIT 2
        DEFINE LCD_EREG PORTB
        DEFINE LCD_EBIT 3
        DEFINE LCD_BITS 4
        DEFINE LCD_LINES 2
    Jun 2006
    it worked fine here... sorry.
    I think Kamikaze47 had the right idea, but mistyped it.
    LCDOut $fe,2,"L:"
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 02:18
  2. 10 bit ADC display on LCD using 16f873
    By pr2don in forum mel PIC BASIC
    Last Post: - 6th March 2010, 18:29
  3. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 15:33
  4. ADC value with 2 decimals on an LCD
    Last Post: - 2nd December 2005, 15:54
  5. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 01:55
