Is this possible that you have to generate it within EasyHID only... or alter some of those .ASM files? Not sure if you can change it AS-IS later in your code.
Hi Steve,
thanks for your response. I've generated is with easyhid. I haven't changed anything in the .asm files.
Just to make sure i'd explain it correctly and you understood what i tried to say.
Let's say you generate your code template with EasyHID with a buffersize of 10... if later in the process you want to increase it... i'm not sure you can do it ONLY in YOUR code. I guess you also have to re-generate the code template with EasyHID again.
