16F88 Analog In
Results 1 to 12 of 12
Thread: 16F88 Analog In
Threaded View
  1. #9
    In theory, you shouldn't take care of ADCONx too much when using ADCIN as the DEFINEs should take care of it for you. The only one thing you might need to set is the Right-Justified results when you use 10Bits resolution. This said, i'm not an ADCIN user.
    try those settings...
    	Define OSC 4
    	Define ADC_BITS 8 	' Set number of bits in result
    	Define ADC_CLOCK 3 	' Set clock source (3=rc)
    	Define ADC_SAMPLEUS 50 	' Set sampling time in uSec
    	CMCON = 7 		' Disable analog comparator
    	ANSEL = %01000000 	' set AN6 (RB7) as analog, others to digital
    	ADCON1.7 = 1		' Right justified results... duh... really needed in 8 bits???
    	adval VAR BYTE
            PAUSE 500 ' lcd settle time
    loop:
    	ADCIN 6, adval 				' Read channel 6 (RB7)
    	Lcdout $fe, 1,"Value: ", DEC adval 	' Clear the LCD and show result
    	Pause 250				' wait a litlle bit
    	Goto loop 				' Do it forever
    Notice that your analog source impedance must be lower than 10K
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 09:38
  2. analog data acquisition with 16f88
    By dru_x in forum Code Examples
    Last Post: - 29th January 2008, 13:38
  3. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 13:55
  4. Anyone Got a 16F88 to Work in Analog?
    By thunderstrike44 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2004, 22:34
  5. 16F88 reading Analog Input
    Last Post: - 30th August 2004, 22:41
