16F88 Analog In
Results 1 to 12 of 12
Thread: 16F88 Analog In
    Unhappy
    Hi Mügel
    the obvious thing here ...
    - is you select Channel 7 ( ADCIN 7 ),
    - Choose channel 1 and 2 for the ADC ,
    - choose channel 4 as default Analog channel,
    - right justify the result ( Ok, here , why not ? ) ,
    - use a 16 bits variable for the result,
    - and , at last use an 8 bits conversion ...
    Might I add your comment tells "read channel 0" for an " ADCIN 7 " ...
    is that clear enough for you ???
    Jan 2008
    Selm, Germany
    Default first time 16F88
    Hello Ace,
    I changed (tried to) the channel but not the comment .
    Puzzling together the analog thing is difficult for me as its the first time.
    Did that with a 12F675 worked great.
    You were second in the following "code saving contest": http://www.picbasic.co.uk/forum/show...ghlight=12F675
    Now I try to save one simple 12F675 and Iīm in trouble again.
    No, What you told below isnīt clear enough for me although it shows the typical "Newbie defines rubbish"
    in this thread:http://www.picbasic.co.uk/forum/show...ht=16f88+adcon
    Melanie tells us that the adcon thingy affects only Porta.
    But the data sheet page 114 tells us (you, not me) how to set the adcon0 register bit to select channel 6 = RB7.
    So, thats REALLY irritating to me.
    so I hope thats clear enough for you.
    I know Iīm juggling bits like shooting in the dark but its always the same:
    search a code that works for me and then modifiing.
    All codes used RA ports as analog input. Canīt use that.
    Quote Originally Posted by Mugelpower View Post
    Hello Ace,
    Mhhhh,
    I do not understand you : you ask for code ready to paste !!!
    No, no, no ...
    Forget the ' 675
    Just take your '88 datasheet ADC section ...
    READ it carefully,
    beginning by the ANSEL config
    WHAT do you have to write to select Channel 6 ( RB 7 ) ???
    Now ADCON 0 Config
    WHAT do you have to write to select RC clock ?, Channel 6 ?, AD OFF ( ADCIN will turn it ON in time )
    Now, ADCON 1 Config
    WHAT do you have to write to select Right justif. ?, Voltage refs ???
    THAT's all you have to do ... but that must suit your harware config !!!
    You don't see here ANY ref to other existing devices ... so, forget that " cut ( ? ) and paste" horrible habit.
    Jan 2008
    Selm, Germany
    Default Horrible habit
    Hi Ace,
    I donīt need a complete code.
    I soldered RB4-7 parallel so it doesnīt matter which of those is my analog input.
    0-2,5V to analog input , showing value on LCD...ready. I know how to set the lcd, how to set some osc defines (and manipulate the xxxx.inc files) the only thing I donīt know is how to tell my 16F88 which input to use as analog in. And I donīt know why I need to set 3 registers for this, or even more.
    It doesnīt matter if the variable dimension is this way or that, will get that clear after some try and error and maybe a little thinking.
    But this ansel adcon thingy makes my head fuzzy.
    when experimenting with serial transmission I often had only one baud rate that worked and didnīt know why.
    Iīm now below even this state because I canīt get my analog in to work without my 12F675.
    Ya...that'll help...
    Probably because the datasheet for that particular PIC tells you what you need to set and where to set it and how to set it to do what you need to do. PBP is good, but sometimes it's not the 'Do-All, End-All', Holy Grail, for everything.
    Seems to be an ongoing problem.
    Different problems in different areas, most seemingly related to problems with reading/understanding (mostly initially reading) the datasheets for the particular PIC you are using.
    PIC#1 (be it whichever type) is very similar to PIC#2 (whichever type)...
    But by no means are they always equal...sometimes they're not even close.
    The 'F628A that you were using is close to the 'F88, but the 'F88 is much newer, with more options in some areas, and, for most practical purposes, the 'F88 isn't even close to the 12F675. They're different families. Basic bare-bones code written for one, will most likely execute on the other without a problem. But once you get into the internal modules of the PICs, register locations change, register names change, register functions change, even bit positions can change.
    Go to Microchip.com, download the latest datasheets for the PICs you are using, and skim thru them.
    Bookmark the pages with registers and functions you are interested in and READ them, comprehend them, play with them.
    In theory, you shouldn't take care of ADCONx too much when using ADCIN as the DEFINEs should take care of it for you. The only one thing you might need to set is the Right-Justified results when you use 10Bits resolution. This said, i'm not an ADCIN user.
    try those settings...
    	Define OSC 4
    	Define ADC_BITS 8 	' Set number of bits in result
    	Define ADC_CLOCK 3 	' Set clock source (3=rc)
    	Define ADC_SAMPLEUS 50 	' Set sampling time in uSec
    	CMCON = 7 		' Disable analog comparator
    	ANSEL = %01000000 	' set AN6 (RB7) as analog, others to digital
    	ADCON1.7 = 1		' Right justified results... duh... really needed in 8 bits???
    	adval VAR BYTE
            PAUSE 500 ' lcd settle time
    loop:
    	ADCIN 6, adval 				' Read channel 6 (RB7)
    	Lcdout $fe, 1,"Value: ", DEC adval 	' Clear the LCD and show result
    	Pause 250				' wait a litlle bit
    	Goto loop 				' Do it forever
    Notice that your analog source impedance must be lower than 10K
    Jan 2008
    Selm, Germany
    Smile Ha!
    Thanks a bundle Mister_E,
    now the code works with your help. had only very small changes to make
    and I guess there will be more PIC-fanatics who can use this:
    '* Name : Ananlog1.BAS *
    '* Author : [Mister_E] *
    '* Notice : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 23.03.2008 *
    '* Version : 1.0 *
    '* Notes : 16F88 LCD 2x8 connected as ususal *
    '* : Portb.7 analog IN 0-2V *
    Include "modedefs.bas"
    Define OSC 4
    Define ADC_BITS 10 ' Set number of bits in result
    adval VAR word
    loop:
    Lcdout $fe, 1,"Val:",dec3 adval ' Clear the LCD and show result
    Goto loop
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. analog data acquisition with 16f88
    By dru_x in forum Code Examples
    Last Post: - 29th January 2008, 14:38
  3. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 14:55
  4. Anyone Got a 16F88 to Work in Analog?
    By thunderstrike44 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2004, 23:34
  5. 16F88 reading Analog Input
    Last Post: - 30th August 2004, 23:41
