16F88 Analog In
Results 1 to 12 of 12
Thread: 16F88 Analog In
    Jan 2008
    Selm, Germany
    Question 16F88 Analog In
    Hi Gurus of Picland!
    yeeees I know thats quite simple thing for you all and I could find it in the data sheet.....but thats my first time on 16F88 . LCD works of course, its just this ansel adcon thingy....
    and i searched in the forum but everyone uses RA inputs for analog. They are used for the lcd so I like to use RB7 which hasnt anything else to do.
    I would appreciate Your help.
    code:
    '* Name : Ananlog1.BAS *
    '* Notice : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 23.03.2008 *
    '* Version : 1.0 *
    '* Notes : 16F88 LCD 2x8 connected as ususal *
    '* : Portb.7 analog IN 0-2V *
    Include "modedefs.bas"
    CMCON = 7 ' PortA = digital I/O
    ANSEL = %00000110 ' Will set RB7 as analog I hope
    ADCON0 = %11100001
    ADCON1 = %10000010
    adval var word 'Create adval to store result
    Define ADC_BITS 8 'Set number of bits in result
    Define ADC_SAMPLEUS 50 ' Set sampling time in uSbut show on LCD Value:3
    Define osc 4
    loop: ADCIN 7, adval ' Read channel 0 to adval
    Lcdout $fe, 1 ' Clear LCD
    Lcdout "Value: ", DEC adval ' Display the decimal value
    Pause 100 ' Wait .1 second
    Goto loop ' Do it forever
    Your ANSEL setting is wrong... RB7 is AN6 and must be set to 1 in ANSEL bit 6.
    Seems you revert bit order or something like that.
    ANSEL=%76543210
    Jan 2008
    Selm, Germany
    Question Ansel setting?
    Mister_E,
    thaks for your suggestion.
    I tried several ansel settings
    from
    ANSEL=%01000000
    to
    ANSEL=%10000000
    to
    ANSEL=%01000110
    and a dozen similar versions.
    when I switch on the LCD shows for half a second "Value:03" and then
    "Value:00"
    Yes..its because of internal bit during startup.
    Switched an Lcdout $FE,1,"Hello"
    Pause 500
    into just to show the PIC works and goes through the loop.
    I could switch input to any RB exept RB03 which is used for the LCD.
    Input voltage is now 0-2,5V .just for checking purposes.
    Do I need a reference voltage?
    Unhappy
    Hi Mügel
    the obvious thing here ...
    - is you select Channel 7 ( ADCIN 7 ),
    - Choose channel 1 and 2 for the ADC ,
    - choose channel 4 as default Analog channel,
    - right justify the result ( Ok, here , why not ? ) ,
    - use a 16 bits variable for the result,
    - and , at last use an 8 bits conversion ...
    Might I add your comment tells "read channel 0" for an " ADCIN 7 " ...
    is that clear enough for you ???
    Jan 2008
    Selm, Germany
    Default first time 16F88
    Hello Ace,
    I changed (tried to) the channel but not the comment .
    Puzzling together the analog thing is difficult for me as its the first time.
    Did that with a 12F675 worked great.
    You were second in the following "code saving contest": http://www.picbasic.co.uk/forum/show...ghlight=12F675
    Now I try to save one simple 12F675 and Iīm in trouble again.
    No, What you told below isnīt clear enough for me although it shows the typical "Newbie defines rubbish"
    in this thread:http://www.picbasic.co.uk/forum/show...ht=16f88+adcon
    Melanie tells us that the adcon thingy affects only Porta.
    But the data sheet page 114 tells us (you, not me) how to set the adcon0 register bit to select channel 6 = RB7.
    So, thats REALLY irritating to me.
    so I hope thats clear enough for you.
    I know Iīm juggling bits like shooting in the dark but its always the same:
    search a code that works for me and then modifiing.
    All codes used RA ports as analog input. Canīt use that.
    Quote Originally Posted by Mugelpower View Post
    Hello Ace,
    Mhhhh,
    I do not understand you : you ask for code ready to paste !!!
    No, no, no ...
    Forget the ' 675
    Just take your '88 datasheet ADC section ...
    READ it carefully,
    beginning by the ANSEL config
    WHAT do you have to write to select Channel 6 ( RB 7 ) ???
    Now ADCON 0 Config
    WHAT do you have to write to select RC clock ?, Channel 6 ?, AD OFF ( ADCIN will turn it ON in time )
    Now, ADCON 1 Config
    WHAT do you have to write to select Right justif. ?, Voltage refs ???
    THAT's all you have to do ... but that must suit your harware config !!!
    You don't see here ANY ref to other existing devices ... so, forget that " cut ( ? ) and paste" horrible habit.
    Jan 2008
    Selm, Germany
    Default Horrible habit
    Hi Ace,
    I donīt need a complete code.
    I soldered RB4-7 parallel so it doesnīt matter which of those is my analog input.
    0-2,5V to analog input , showing value on LCD...ready. I know how to set the lcd, how to set some osc defines (and manipulate the xxxx.inc files) the only thing I donīt know is how to tell my 16F88 which input to use as analog in. And I donīt know why I need to set 3 registers for this, or even more.
    It doesnīt matter if the variable dimension is this way or that, will get that clear after some try and error and maybe a little thinking.
    But this ansel adcon thingy makes my head fuzzy.
    when experimenting with serial transmission I often had only one baud rate that worked and didnīt know why.
    Iīm now below even this state because I canīt get my analog in to work without my 12F675.
    skimask's Avatar
    skimask Guest
    Ya...that'll help...
    Probably because the datasheet for that particular PIC tells you what you need to set and where to set it and how to set it to do what you need to do. PBP is good, but sometimes it's not the 'Do-All, End-All', Holy Grail, for everything.
    Seems to be an ongoing problem.
    Different problems in different areas, most seemingly related to problems with reading/understanding (mostly initially reading) the datasheets for the particular PIC you are using.
    PIC#1 (be it whichever type) is very similar to PIC#2 (whichever type)...
    But by no means are they always equal...sometimes they're not even close.
    The 'F628A that you were using is close to the 'F88, but the 'F88 is much newer, with more options in some areas, and, for most practical purposes, the 'F88 isn't even close to the 12F675. They're different families. Basic bare-bones code written for one, will most likely execute on the other without a problem. But once you get into the internal modules of the PICs, register locations change, register names change, register functions change, even bit positions can change.
    Go to Microchip.com, download the latest datasheets for the PICs you are using, and skim thru them.
    Bookmark the pages with registers and functions you are interested in and READ them, comprehend them, play with them.
    In theory, you shouldn't take care of ADCONx too much when using ADCIN as the DEFINEs should take care of it for you. The only one thing you might need to set is the Right-Justified results when you use 10Bits resolution. This said, i'm not an ADCIN user.
    try those settings...
    	Define OSC 4
    	Define ADC_BITS 8 	' Set number of bits in result
    	Define ADC_CLOCK 3 	' Set clock source (3=rc)
    	Define ADC_SAMPLEUS 50 	' Set sampling time in uSec
    	CMCON = 7 		' Disable analog comparator
    	ANSEL = %01000000 	' set AN6 (RB7) as analog, others to digital
    	ADCON1.7 = 1		' Right justified results... duh... really needed in 8 bits???
    	adval VAR BYTE
            PAUSE 500 ' lcd settle time
    loop:
    	ADCIN 6, adval 				' Read channel 6 (RB7)
    	Lcdout $fe, 1,"Value: ", DEC adval 	' Clear the LCD and show result
    	Pause 250				' wait a litlle bit
    Notice that your analog source impedance must be lower than 10K
    Jan 2008
    Selm, Germany
    Smile Ha!
    Thanks a bundle Mister_E,
    now the code works with your help. had only very small changes to make
    and I guess there will be more PIC-fanatics who can use this:
    '* Author : [Mister_E] *
    '* Version : 1.0 *
    Define OSC 4
    adval VAR word
    loop:
    Lcdout $fe, 1,"Val:",dec3 adval ' Clear the LCD and show result
    Goto loop
    Mugel,
    The most important thing is not what i'd done... the most important thing for you now is to understand what i'd done. Period.
    You're welcome anyways
    Jan 2008
    Selm, Germany
    Talking Understanding things
    Mister_E,
    theres quite a difference between understanding something and doing something by yourself. After everything works all falls into place and looks logical.
    For me it was important to get the starting point without inventing the wheel again.
    You helped me a lot and my work goes like this:
    looking at a code, trying to understand, modifiing for own needs and getting back to the beginning if everything fails.
    I guess this method is acceptable. fact is: if you got enough of the time*intelligence product you can act like Conrad Zuse or Albert Einstein and invent everything from scratch.
    The datasheets are very useful for programmers who are used to this kind of work. That may take years for me to get that far. If you learn something new without teacher or advisor you experience way more work and lots of wrong ways that could be avoided if only somebody tells you in the right moment NOT to do something specific. Two years ago programming Microcontrollers was mentally out of reach for me. Now Iīm doing that myself and got some useful gadgets that partly astonished my friends because they by themself donīt grasp more than basic electronics if even that bit . They thought you need an engineering degree in informatics to get that straight. for my part I got an engineering degree, but in mechanical engineering and thats really far away from electronics. Most of my student friends thought of electronics as a "never touch" thing. The guy that knew about transistors was suspicious.
    But PBP and this forum make things go!
    Point is: couldnīt get it done without "a little help from my friends". Thats it: Help.
    Thanks a bundle.
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. analog data acquisition with 16f88
    By dru_x in forum Code Examples
    Last Post: - 29th January 2008, 14:38
  3. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 14:55
  4. Anyone Got a 16F88 to Work in Analog?
    By thunderstrike44 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2004, 23:34
  5. 16F88 reading Analog Input
    Last Post: - 30th August 2004, 23:41
