Unpacking a PICkit 2 Programmer/Debugger
Results 1 to 21 of 21
    See the first section here http://melabs.com/support/mplab.htm for info on using PBP with
    MPLAB version 8.20 or later.
    MeLabs is working on it, but it's not ready yet. If you want to use MPLAB with the latest
    version of PBP, you'll need to install MPLAB version 8.15a or earlier.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Been making a lot of progress, Bruce.
    Now I have a question again.
    When using the simulator, my switches (which in hardware have a pull-up) show to be low; how can i change that so that I could use the stimulus to trigger these?
    Anand
    Click in the stimulus Action window for options. See attached screen capture.
    -Bruce
    tech at rentron.com
    Yes, I discovered that, Bruce. But does 'pulse low' mean that input would otherwise be high by default, as it would with a pull-up? Or does one have to set it high every time, before a pulse low can be used?
    Anand
    Weak pull-ups on ports not implemented in MPLAB SIM. Use Toggle.
    -Bruce
    tech at rentron.com
    Well, I asked because 1. did not read the mentioned article by Melabs and 2. I run your tutorial with no problems. I did not though compiled yet any program in 8.30...
  1. PICkit 2 and RBC interrupts
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 4th April 2009, 03:33
  2. PICkit 2 for £9.99 inc P&P
    By Agent36 in forum General
    Last Post: - 17th November 2008, 00:44
  3. PicKit 2 Questions
    By dmairspotter in forum General
    Last Post: - 11th November 2007, 22:10
  5. Programming from MicroStudio to a PICKit 2
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 30th November 2006, 04:56
