For sure ADCIN will work for any PIC. This is the easy solution to get from them. But it takes a bit more code space than if you access directly to the registers.
i attach an example from melabs website.
adval  var word					'Create adval to store result
	TRISA = %11111111  	' Set PORTA to all input
    ADCON1 = %10000010 	' Set PORTA analog and RIGHT justify result
	ADCON0 = %11000001	' Configure and turn on A/D Module
    Pause 500       	' Wait .5 second
loop: 		ADCON0.2 = 1					'Start Conversion
notdone:	pause 5
			if ADCON0.2 = 1 Then notdone	'wait for low on bit-2 of ADCON0, conversion finished
			adval.highbyte = ADRESH			'move HIGH byte of result to adval
			adval.lowbyte = ADRESL			'move LOW byte of result to adval
	    	Lcdout $fe, 1   				'Clear screen
        	Lcdout "Value: ", DEC adval		'Display the decimal value
        	Pause 100       				'Wait .1 second
       		Goto loop       				'Do it forever
Some programmer prefer to use this way... nobody's working the same way.
regards
