mister_e: Those code lines were in my program, but I didn't include them above.
I added the pause statement and it helped - a little. I now get different readings from *no* input compared to *some* input. No input to A1 produces a response of essentially 0 from the ADC. When voltage is applied (in this case 2.5v) it goes back to the number it used to give before the PAUSE statement was added... approximately 800 (out of 1024)
Soooo... it knows whether somethign is there or not, but it can't discriminate the real value. When I get home tonight I'll try varying the voltage that that channel sees and see if the result changes... I'm guessing not.
BTW, I'm using an Allegro current module that outputs a voltage of 0-5v depending on the input current. 0 A current should output 2.5v from the IC, which is what the ADC should be seeing when I plug it in.
Bruce - I'm using a voltage divider and reading half of that value. The math you helped me with multiplies the result by 2 to get the real value on the screen.
-Jeff
