Using 4 input to control 10 output
Results 1 to 8 of 8
    Nov 2004
    malawi
    Default Using 4 input to control 10 output
    Dear all.
    first off all i would like to apologise my bad english.
    Iam been working a robot project control via serial com PC using 4 channel RF( thanks to melaine that give source code on this forum). Transmitter section, iam using PIC 16F626 and to control 4 (led) output RA.0 to RA.3 that i connected to Transmitter module (4 ch).
    On Reciever section, Reciever module is connected to PIC16F877 RB.0 to RB.3.
    10 Output(led) is connected to RA.0 to RC.2
    The problem is how to control the 10 LED individually using only 4 input?
    i hope that this imformation can inderstand my project situation
    regards
    cibotsan
    The result will be based on this table
    state of inputs          state of outputs
    0000                       0000000001
    0001                       0000000010
    0010                       0000000100
    0011                       0000001000
    0100                       0000010000
    0101                       0000100000
    etc
    simple code here...
    ADCON1=7 ;disable ADC
    TRISB=$FF
    TRISA=0
    TRISC=0
    InputBCD VAR PORTB
    Out1_8   VAR PORTA ;first 5 LEDs
    Out9_10  VAR PORTC ;last 5 LEDs
    GetInput VAR BYTE
    BCDToDEC VAR BYTE
    Out1_5=0
    Out6_10=0
    start:
    Getinput=InputBCD
    Select case Getinput
               Case is<=5
                       Out6_10=0
                       BCDToDEC=dcd Getinput
                       Out1_5= BCDToDEC
               Case is>=6
                        Out1_5=0
                        BCDToDEC=dcd (GetInput-6)
                        Out6_10= BCDToDEC
    End Select
    goto start
    it's suppose to work. Try and post reply on this. There's several different way to do this
    Nov 2004
    malawi
    Thanks steve .
    any how i try it but ist wont work.for you imformation.when i run it all output is on all while input = 0.When i set any input = 1 , the only ouput Rc0 =0 below is my code .
    TRISB=$FF
    TRISA=0
    TRISC=0
    InputBCD VAR PORTB
    Out1_5 VAR PORTA.0 ;first 5 LEDs
    Out2_5 VAR PORTA.1 ;first 5 LEDs
    Out3_5 VAR PORTA.2 ;first 5 LEDs
    Out4_5 VAR PORTA.3 ;first 5 LEDs
    Out5_5 VAR PORTA.4 ;first 5 LEDs
    Out6_10 VAR PORTC.0 ;last 5 LEDs
    Out7_10 VAR PORTC.1 ;last 5 LEDs
    Out8_10 VAR PORTC.2 ;last 5 LEDs
    Out9_10 VAR PORTC.3 ;last 5 LEDs
    Out10_10 VAR PORTC.4 ;last 5 LEDs
    GetInput VAR BYTE
    BCDToDEC VAR BYTE
    Out1_5=0
    Out6_10=0
    start:
    Getinput=InputBCD
    Case is<=5
    Out6_10=0
    Out1_5= BCDToDEC
    Case is>=6
    Out1_5=0
    Out6_10= BCDToDEC
    End Select
    goto start
    "Thanks steve .
    any how i try it but ist wont work.for you imformation.when i run it all output is on all while input = 0.When i set any input = 1 , the only ouput Rc0 =0 below is my code ."
    can you provide the output table from transmitter you have and receiver you want?
    maybe
    transmitter:
    1111 = receiver out1
    1110 = receiver out2
    1101 = receiver out3
    1100 = receiver out4
    1011 = receiver out5
    let us know
    Nov 2004
    malawi
    thanks again steve
    okey whats i need is like this
    0000 all output =0
    0001 out1 =1 out3=1
    0010 out2 = 1 out 4 =1
    0100 out1=1 out4=1
    1000 out2=1 out3=1
    0011 out5=1
    0110 out6=1
    1100 out7=1
    0111 out8=1
    1110 out9=1
    1111 out10=1
    its is possible to change from out put to a label? because i will use to control a different output devices for example RC servo, DC motor ,relay etc?
    "its is possible to change from out put to a label? because i will use to control a different output devices for example RC servo, DC motor ,relay etc?"
    sure....
    TRISB=$FF
    TRISA=0
    TRISC=0
    Out1     VAR PORTA.0
    Out2     VAR PORTA.1
    Out3     VAR PORTA.2
    Out4     VAR PORTA.3
    Out5     VAR PORTA.4
    Out6     VAR PORTC.0
    Out7     VAR PORTC.1
    Out8     VAR PORTC.2
    Out9     VAR PORTC.3
    Out10    VAR PORTC.4
    Rinput   VAR PORTB
    GetInput VAR BYTE
    Gosub ResetOutputPort
    start:
    GetInput=Rinput & $0F ;will mask the MSB bits of PORTB
    select case Getinput
         Case 0
         Case 1
            Out1=1
            Out3=1
         Case 2
            Out2=1
            Out4=1
         Case 3
            Out5=1
         Case 4
            Out1=1
            Out4=1
         Case 6
            Out6=1
         Case 7
            Out8=1
         Case 8
            Out2=1
            Out3=1
         Case 12
            Out7=1
         Case 14
            Out9=1
         Case 15
            Out10=1
    End Select
    goto start
    ResetOutputPort:
    PORTA=0
    PORTC=0
    now it's really suppose to match with your specific need.
    NEXT!!!
    Nov 2004
    malawi
    Yes!!! its working, thanks again steve you safe my robot life.can i buy you a drink?If i have further problem i will online again.
    hi cibotsan,
    Great to know that everything work for you !!!
    hehe nothing exepensive.... 50 year age PORTO will do the job
    best regards
  1. problem with input and output (18F452)
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 00:21
  2. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 21:31
  3. Serious Serial Situation Setbacks...
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
