newbie question
Results 1 to 11 of 11
Thread: newbie question
    Quote Originally Posted by daphne8888 View Post
    i mean that i connect a port to a push button where is the other end is connected to a pull up resistor with 5V. when i push the button, it will on. but after i release, it should b off but why my pic on the port still is 'high' ? got what coding that can change the input that "high" to "low"?
    Still doesn't make much sense....losing something in the translation....
    But if I'm getting what you're saying, the 'high' to 'low' command is right in the PBP manual.
    Mar 2008
    Texas, USA
    The diagram says a lot.
    The end of the switches that is connected to the resistors should go to ground and the resistors should go to the pin ports.
    PIN<--------->SWITCH<---------->GROUND
         L----------->RESISTOR<-------->Vdd(power)
    Port (pin) Logic is HIGH with switch idle, LOW when switch is pushed. This is for the first picture, when (unlike what you said) the resistors are tied to ground, In the second picture I can't see where they are tied.
    Anyway I NOW understand what you are saying. What's going on is you push the button for a high, the port goes high, but when you release the switch, the port still reads high. That's called a "FLOATING INPUT" and a poor design. Use the logic I show above. It's a good way to keep the pins from floating (not high, not low, but read as high).
    Quote Originally Posted by JD123 View Post
    The diagram says a lot........It's a good way to keep the pins from floating (not high, not low, but read as high).
    Now the translation makes sense....somewhat....
    Mar 2008
    y the data lines of my lcd from pic doesnt light up? is it due to the programming problem ? or due to the pic ports? because i connect the data lines to port B.4-B.7 of pic.
    Mar 2008
    Texas, USA
    I can't make out that part as the pictures don't show those connections in full. Anyway, use pull-up resistors on the data pins going to the LCD or the weak pull-up port option if it's available on those pins. Past that, it maybe a code issue.
    Post a clear picture of the pins to LCD connections and post some code.
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
    Mar 2008
    Thanks JD123.i have my work done half way!but now i have another problem.I'm trying to write a simple password system which can confirm the password that i keyin at the beginning.Do u have any idea?i try to search through internet but cant find the one i really understand with.
    i also attach my circuit diagram and some coding.Please tell me if i make any mistake.Thanks again.
    Mar 2008
    Texas, USA
    For a password, I'd use logic like this:
    (Every key pressed sends "#" so that someone looking over your shoulder can't see what you entered.)
    password is a an array that you setup and holds the password value
    for i = 0 to 3 'for 4 digit password
    read keys
    if no key, re-read keys
    if key pressed <> password[i] then fail = 1
    send LCD "#", no CR of LF
    next i
    if fail = 0 then go forward, else LCD "FAIL" (or something), clear LCD, fail = 0 and go back to password loop
    This only the logic flow, not verbatim code.
  1. Newbie 74hc595 question
    By manjero in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 23:22
  2. newbie with serial com question...
    Last Post: - 16th December 2006, 06:34
  3. Newbie Question - Info Please
    By ehoskins in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2006, 15:50
  4. Greetings from Newbie and a question
    Last Post: - 24th July 2006, 16:52
  5. Newbie question
    By senojlr in forum General
    Last Post: - 11th April 2006, 22:23
