Capacitor on PIC output
Results 1 to 11 of 11
    Mar 2008
    Texas, USA
    Okay, Michael... I just didn't see that in your code.
    Still would like to learn why I had that problem.
    Because actually when you run code over and over again that includes HIGH it's pulsing the output pin again and again based on the instruction clocks square wave?
    But when you call HIGH just once and leave the output pin alone, it's a steady DC that is stable.
    start
    If porta.0 = 0 then
    high portd.0
    do other stuff
    If porta.0 = 0 then
    high portd.0
    do other stuff
    If porta.0 = 0 then
    high portd.0
    goto start
    Not good when a capacitor is on the output?
  1. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  2. Can a pic do several things at once?
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 10th May 2008, 01:09
  3. PIC 18f1220 EUSART Baud Rate Cache Problem
    By wklose99 in forum Off Topic
    Last Post: - 15th April 2008, 01:39
  4. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  5. PIC 2 PIC communication
    By Mario in forum Forum Requests
    Last Post: - 28th April 2006, 02:56
