Navtex Receiver
Results 1 to 18 of 18
Thread: Navtex Receiver
    in your asm code... ; if sample = inphase then donothing
    think about it a little bit
    Feb 2005
    I stack now. I know that one sitor bit is 10msec. so i use tmr0 to find if it is in phase with samples, but how i know if i am in the start of sitor bit or in 3 msec after? I say that 10 samples is 1 sitor bit ok but i don't know if i start from the begining.Can you explain it to me mister_e?
    Here's a tips on how to mix ASM and PBP.
            '    Using PIC16F88
            @ DEVICE INTRC_OSC, LVP_OFF, WDT_OFF, MCLR_OFF
            OSCCON=%01101000
            ANSEL=%00000000
            CMCON=%00000111
            trisa = %11111111
            trisb = %00000001
            DEFINE HSER_SPBRG 25  ' 9600 Baud @ 4MHz, 0.16%
            CounterA    var byte BANK0
            CLEAR
    Start:
            asm
                    CHK?RP PORTB
                    BTFSC   PORTB,0
                    GOTO $-1
                    INCF _CounterA,F
            HSEROUT ["CounterA=",DEC CounterA,13,10]
            PAUSE 200
            GOTO START
    You define your variable in PBP, then you access them in ASM. Possible to use the other way... BUT not 100% sure if this is safe though... sure it isn't 'cause you can't know for sure where PBP will place it's own variables.
    Feb 2005
    Thanks for your reply mister_e. Tomorrow i will try in PBP and i will tell you my results.
    Feb 2005
    Default TMR0 to interrups every 1msec
    i am using darrel's interrupts and 20MHz crystal. With mister_e calculator i found that i want prescaler 1:32 and preload 99 into tmr0.I don't know how to preload the value into timer.below i have the interrupt routine of my program. Is this correct for preload the value?
    '---[TMR0 - interrupt handler]--------------------------------------------------
    Tick0: ;every 1ms occurs
    ;make space for new sample
    cp_old=cp_new ;save old value
    cp_new.highbyte=CCPR1H ;take new capture
    cp_new.lowbyte=CCPR1L
    gosub samplebit ;take the sample bit
    TMR0=99
    @ INT_RETURN
    thanks
    if you're still using the 16F876 and want to have an interrupt each ~1mSec.. then yes.
    Easy huh?
    Feb 2005
    Thanks mister_e.it was very easy to be true. I would like to ask you what is in your timer calc the re-load variable because i can't understand it.
    thanks again for you reply.
    regards
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. 433 Mhz Data Receiver
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 29th November 2010, 02:26
  3. RC Servo Receiver
    By Ioannis in forum General
    Last Post: - 23rd October 2007, 06:56
  4. PIC16F877 with GPS receiver
    By rocketqueen in forum GPS
    Last Post: - 15th November 2006, 21:56
  5. interfacing gps receiver with 16f877a
    By sakhyvava in forum GPS
    Last Post: - 27th September 2006, 09:13
