Help for my project(16f877,2x16LCD,)
Results 1 to 22 of 22
    but the word "value" always flickering , why ?
    Probably because something is overwriting it or clearing the screen, then you re-print the VALUE on the LCD...
    as i said before , whene there is 5V , i don't want any bars , there must be full bars at 3.9V
    Simple math
    Minimum = 5V (1023 ADC counts)
    Maximum = 3.9V (798 ADC counts)
    Spread = 1.1V (225 counts)
    raw = 1024 - raw 'flips the value upside-down
    raw = raw / 14 '14 counts per box, assuming 16 boxes
    Surely you can do something with that...
    Mar 2008
    Okey my friend , thank you for your patience and for your helps
    Today is enough for me ;
    i'm working about this project from 9 o'clock to now.
    I think , it's time to make my brain free.
    And one last question ; i don't know that you are interested in integrated circuits; if you are ; i want to ask something.
    I have 2 op-amps LM358 and i learned that , the maximum supply current for LM358 is 600mA . I have a power supply with 6-9-12-15 adjustable ; and it says , it can give a current of 2.5A
    So, if i connect it to my op-amps , do they blow out ?
    Thank you .
    The op amps will be fine. The PS rating is the maximum it can handle, the op amps will only draw what they need.
    As for the flicker, you need a pause of maybe 100 in the loop.
