Help for my project(16f877,2x16LCD,)
Results 1 to 22 of 22
    Mar 2008
    Sorry for the flood , but i must ;
    i changed the ADC codes , but volt variable does not accept floating numbers :
    START:
    ADCIN 0,RAW
    LOOK : IF ADCON0.2=1 THEN LOOK
    Volt=(0,0048828125*RAW)*1000
    MVolt=Volt//10 ' Mvolt = Volt mod 10
    LCDOUT $FE,2,"VOLT=",#VOLT,",",#Mvolt
    PAUSE 500
    GOTO START
    Quote Originally Posted by karamastik View Post
    Neither does anything else in PBP...
    PORTA=1 : RAW var word : volt var long
    START: ADCIN 0,RAW : IF ADCON0.2=1 THEN START
    Volt = Raw * 4882813 'round up
    LCDOUT $FE , 2 , "V=" , DEC ( volt dig 9 ) , "." , DEC ( volt dig 8 ) , DEC ( volt dig 7 )
    LCDOUT DEC ( volt dig 6 ) , DEC ( volt dig 5 ) , DEC ( volt dig 4 ) , DEC ( volt dig 3 )
    LCDOUT DEC ( volt dig 2 ) , DEC ( volt dig 1 ) , DEC ( volt dig 0 ) 'get all them digits in there
    PAUSE 500
    GOTO START
    Mar 2008
    I was at school ,sorry for the delay.
    Thanks for the help but in pbp , i saw that there is no " long " .
    It gives error.
    It gives error.
    There is if you upgrade to PBP 2.50a.
    Mar 2008
    Hello again !
    I changed my code like that :
    (Arkadaşlar yok mu yardımcı olacak ? )
    @ DEVICE pic16F877
    @ DEVICE pic16F877, WDT_on
    @ DEVICE pic16F877, PWRT_ON
    @ DEVICE pic16F877, PROTECT_OFF
    @ DEVICE pic16F877, HS_OSC
    TRISA=%00000001
    TRISB=0
    TRISE=0
    LCDOUT $FE, $40, $00, $1F, $1F, $1F, $1F, $1F, $1F, $00
    bar var byte
    raw var word
    I var byte
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 0
    DEFINE LCD_RWREG PORTE
    DEFINE LCD_RWBIT 2
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1000
    DEFINE LCD_DATAUS 225
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 2
    DEFINE ADC_SAMPLEUS 100
    ADCON1=%10001110
    LOW PORTE.2
    LCDOUT $FE,1
    PAUSE 200
    ADCIN 0,raw
    bar=(1023-raw)/64
    lcdout $fe,2
    for I=1 to bar
    lcdout ,255
    next
    Is the idea correct , isn't it ?
    But it does not work
    Are you using a 16F877 or 16F877A?
    Probably doesn't matter much, but, put the config registers first, then your define's, then you variables, then your code.
    @ DEVICE pic16F877
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EBIT 0
    DEFINE LCD_RWBIT 2
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 2
    bar var byte:raw var word:I var byte
    trisa=1:trisb=0:trise=0:lcdout $FE,$40,0,$1F,$1F,$1F,$1F,$1F,$1F,0,$fe,1
    ADCON1=$8e:PAUSE 200:ADCIN 0,raw:bar=(1023-raw)/64:lcdout $fe,2:for I=1 to bar
    lcdout ,255:next I
    Looks like something might be missing from that lcdout command...(and the next I shouldn't matter, but it might).
    How do you know you ADCIN is actually reading something?
    Have you tried just reading the RAW value and displaying it in a loop?
    lcdout DEC3 RAW
    Mar 2008
    Hello
    I'm using 16f877;
    i changed the lcdout command like yours and
    here , i checked for the ADC reading:
    @ DEVICE pic16F877
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EBIT 0
    DEFINE LCD_RWBIT 2
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 2
    bar var byte
    raw var word
    I var byte
    trisa=1
    trisb=0
    trise=0
    ADCON1=$8e
    PAUSE 200
    ADCIN 0,raw
    bar=(1023-raw)/64
    for I=1 to bar
    lcdout dec3 raw
    next I
    there is a 16 digit number : 2732732732732732 and does not change;
    if i reset the pic , there is another number 2742742742742742 , so goes on ...
    I think i it couldn't read raw.
    And the number does not change;maybe my loop is wrong
