Acetronics,
you lost me there...
Hi, Ruijc
Why ( and where ! ) use a 150 °C range sensor on a model ???
Good question.
It's for the engine temp.
The max 120ºC of the DS18B20 is not enough.
I need to be able to read safely up to 140ºC.
I know you will say that the engine cannot reach that temperature unless it's toast, but the real thing is that with 30% nitro they can have peeks of 130ºC/135ºC. Not too good for the engine, it's true, but i need to measure it's peeks to know how the engine is running in mid air
Do not tell me you didn't know that :
http://www.venom-group.com/print_mot...structions.pdf
Now i see what you mean.
I did not knew this.
Sensor reaches 200ºC ??? wow...and now i undestand why you recomended NTCs.
But this is a failsafe unit.
I know this one instead:
http://www.rcmodels.org/csm/carbsmart.pdf
I believe it's by far the best idea.
Apart from these 2...
My circuit is not like any of these.
It just stores the values, nothing else.
Ahhhhh,
CSM !!! I bought one gyro from them ( ICG360 ) Heading "lock" was gently unsteady ( ! )... carefully trimmed parameters for a plane.
and then ... servo got dead-locked to neutral - and no way to reset the gyro parameters !!!
No help from CSG nor ( except buy the new 540 model at a fair price ...)
The sensor ( and its NTC ) is now in my Sensors box !!!
Yeah...gyros i only like futaba's my self
how about the code...will this work ok for 2,5V ref?And i have to change the code to:
temp= (in */2500)>>2
Is this right ?
